Exterior
Water just rolls off
Durable Water-Repellent Coating
Gyeon Q² FabricCoat provides long-lasting protection for all types of textile surfaces. Thanks to its advanced formula, it creates an invisible layer that repels water and prevents moisture from penetrating the fibers. This ensures that fabrics like car upholstery, carpets, and fabric-covered surfaces stay dry and clean, even in heavy rain. The strong adhesion to textiles guarantees long-term effectiveness, reducing the need for frequent reapplication. With Gyeon Q² FabricCoat, your interior stays fresh and free from water damage.
No chance for mud and spills
Invisible Barrier Against Dirt
In addition to being water-repellent, Gyeon Q² FabricCoat also acts as an effective shield against dirt and stains. Thanks to its innovative SiO₂ technology, it prevents liquids, mud, and dust from penetrating deep into the fabric. Spilled drinks or splattered dirt have no chance of leaving stubborn stains, keeping your upholstery cleaner for longer. This makes it ideal for everyday use in cars, on furniture, and even on outdoor fabrics. Cleaning becomes much easier since dirt struggles to cling to the surface.
Drop the top (but stay dry)
Perfect for Convertible Tops
Convertible tops are constantly exposed to changing weather conditions, from scorching sun to heavy rain. Gyeon Q² FabricCoat creates a strong protective layer that makes the roof water-repellent and prevents dirt and algae buildup. This keeps the fabric in top condition and reduces the risk of mold growth and discoloration. Thanks to its long-lasting effect, you can worry less about maintaining your convertible. Rain effortlessly beads up and rolls off, allowing you to enjoy a clean and well-protected roof for longer.
Gyeon Q² FabricCoat is a durable water-repellent coating for textiles. Not only does it protect the surface, but it also impregnates the fibers, creating a long-lasting barrier against water and dirt. The UV protection helps prevent color fading. The formula contains only the highest quality ingredients to stand out in durability compared to other similar products. Suitable for upholstery, mats, carpets, and convertible tops.
Consumption is approximately 80ml of product per 1m².
| Product number | GYFAB04 |
| Additives | Ceramic (SiO²) |
| Durability | 6-12 months |
| Especially for | Fabric convertible roofs |
| Suitable for material | Textile |
| Volume | Small (0 - 400ml) |
- Reinigen: Zorg voor een volledig schoon en droog oppervlak.
- Aanbrengen: Spray gelijkmatig op het textiel (verbruik: ca. 80ml/m2.
- Inwerken: Wrijf het product licht in met een zachte borstel of een handschoen voor maximale vezelbinding.
- Drogen: Laat het oppervlak minimaal 12 uur rusten in een droge omgeving. Vermijd contact met water tijdens het uitharden.
Let op: Altijd gebruiken in een goed geventileerde ruimte. Dek omliggende plastic- of lakdelen af om overspray te voorkomen.
Niet alleen voor de auto
Ik heb deze gebruikt omdat we ooit een keer een ongelukje hadden gehad met onze dochter in de auto waarbij ze alles had onder gespuugd. Iedere ouder die dit heeft meegemaakt weet hoe verschrikkelijk dat is. Voor alles en iedereen.. Tip: ga niet te snel met een klein kindje de hoogte in, in de vorm van een Gletscher bezoek. Maar dat ter zijde.
Ik ben nogal fan van Gyeon vanwege goede ervaringen met andere Gyeon-producten en daarom dit spul gekocht om de bekleding preventief te behandelen. En ondertussen heb ik ook onze keuken-stoelen gedaan, schoenen.. geweldig! Ik heb voor de keukenstoelen 3 laagjes / sprays gedaan. Dat werkt beter dan 1 "dikke" laag. Wees sowieso wat voorzichtig met het sprayen want je gebruikt als snel te veel.
Zoals ik het nu heb gedaan;
1. Zorg voor een schoon en droog oppervlak.
2. 1x sprayen, laten intrekken. Gaat volgens Gyeon vrij snel maar ik heb het toch een kwartiertje laten kuren.
3. Herhaal stap 2 nog 2 keer
Ik vind het lastig om iets te zeggen over de duurzaamheid. Geen idee hoe lang dit blijft werken en wanneer je dit opnieuw zou moeten herhalen.
Bijna niet voor te stellen.
Naar aanleiding van het filmpje een keer een kleine flacon besteld. Nu toch de grote besteld want het werkt echt perfect. Mijn alcantara stoelen zijn tot in detail beschermd. Ik spuit ook me schoenen ermee in!
Super zuinig en heel effectief
Super zuinig in gebruik door zeer fijne nevel. Even proberen met de afstand, niet teveel in één keer aanbrengen. De laag intensief geforceerd drogen geeft het beste resultaat. Neem gewoon een fohn en een hoge stand. Damp niet inademen, geur geeft daarvoor voldoende aanleiding. Sprayer is na afloop los te draaien en met enige handigheid leeg te spuiten in het flesje. Bespaart en houdt de sprayer schoon zodat hij niet verstopt.
