Q² FabricCoat - 400ml
Art. nr. GYFAB04
4.4 (18)
  • Stay dry, stay happy
    The Ultimate Textile Protection
Water just rolls off
Durable Water-Repellent Coating
Gyeon Q² FabricCoat provides long-lasting protection for all types of textile surfaces. Thanks to its advanced formula, it creates an invisible layer that repels water and prevents moisture from penetrating the fibers. This ensures that fabrics like car upholstery, carpets, and fabric-covered surfaces stay dry and clean, even in heavy rain. The strong adhesion to textiles guarantees long-term effectiveness, reducing the need for frequent reapplication. With Gyeon Q² FabricCoat, your interior stays fresh and free from water damage.
No chance for mud and spills
Invisible Barrier Against Dirt
In addition to being water-repellent, Gyeon Q² FabricCoat also acts as an effective shield against dirt and stains. Thanks to its innovative SiO₂ technology, it prevents liquids, mud, and dust from penetrating deep into the fabric. Spilled drinks or splattered dirt have no chance of leaving stubborn stains, keeping your upholstery cleaner for longer. This makes it ideal for everyday use in cars, on furniture, and even on outdoor fabrics. Cleaning becomes much easier since dirt struggles to cling to the surface.
Drop the top (but stay dry)
Perfect for Convertible Tops
Convertible tops are constantly exposed to changing weather conditions, from scorching sun to heavy rain. Gyeon Q² FabricCoat creates a strong protective layer that makes the roof water-repellent and prevents dirt and algae buildup. This keeps the fabric in top condition and reduces the risk of mold growth and discoloration. Thanks to its long-lasting effect, you can worry less about maintaining your convertible. Rain effortlessly beads up and rolls off, allowing you to enjoy a clean and well-protected roof for longer.
Gyeon Q² FabricCoat is a durable water-repellent coating for textiles. Not only does it protect the surface, but it also impregnates the fibers, creating a long-lasting barrier against water and dirt. The UV protection helps prevent color fading. The formula contains only the highest quality ingredients to stand out in durability compared to other similar products. Suitable for upholstery, mats, carpets, and convertible tops.
Consumption is approximately 80ml of product per 1m².
Product number GYFAB04
Additives Ceramic (SiO²)
Durability 6-12 months
Especially for Fabric convertible roofs
Suitable for material Textile
Volume Small (0 - 400ml)
  • Reinigen: Zorg voor een volledig schoon en droog oppervlak.
  • Aanbrengen: Spray gelijkmatig op het textiel (verbruik: ca. 80ml/m2.
  • Inwerken: Wrijf het product licht in met een zachte borstel of een handschoen voor maximale vezelbinding.
  • Drogen: Laat het oppervlak minimaal 12 uur rusten in een droge omgeving. Vermijd contact met water tijdens het uitharden.
Let op: Altijd gebruiken in een goed geventileerde ruimte. Dek omliggende plastic- of lakdelen af om overspray te voorkomen.
Ja, dit is cruciaal. De ondergrond moet volledig schoon en kurkdroog zijn. Gebruik een textielreiniger om vet en vuil te verwijderen, spoel goed na zodat er geen zeepresten achterblijven, en laat het textiel volledig drogen voordat je de FabricCoat aanbrengt.
FabricCoat is geschikt voor bijna alle soorten textiel, zowel binnen als buiten de auto. Denk aan stoffen stoelbekleding, vloermatten, tapijt en – zeer populair – stoffen cabriodaken. Het is zelfs effectief op Alcantara.
Nee, FabricCoat is kleurloos en laat de stof ademen. Bij correct gebruik verandert de 'look & feel' van het textiel niet; het blijft net zo zacht als voorheen, maar dan met de extra eigenschappen van een coating.
Ja, FabricCoat bevat sterke UV-beschermers. Dit helpt voorkomen dat stoffen bekleding of cabriodaken vaal worden en hun kleur verliezen door langdurige blootstelling aan zonlicht.
Na het aanbrengen moet de coating minimaal 12 tot 24 uur drogen in een droge, stofvrije omgeving. Vermijd in deze periode contact met water. Het volledig uitharden kan tot 48 uur duren; daarna is de bescherming optimaal.
Bukit Batok Crescent 1
04-25 Singapore, Singapore
H372: Causes damage to organs through prolonged or repeated exposure .
H411: Toxic to aquatic life with long lasting effects.
Flame: Flammable Exclamation Mark: Health hazard/Hazardous to the ozone layer Health hazard: Serious health hazard Environment: Hazardous to the environment
Nog niet gebruikt maar een gebruiksaanwijzing zou wel makkelijk zijn, hoe toe te passen en eventuele voorbewerkingen.
Paul Vingerhoets - 29 March 2016
Geweldig
Op advies van carclean Gyeon fabric coat op mijn fietstassen gespoten.
Eerst goed schoon gemaakt met APC van meguiars.
Later 3 lagen opgespoten. Na elke laag 12 uur gewacht.
Aanbrengen ging zeer makkelijk.
Maar, echt beading geeft het niet. Had er meer van verwacht.
Volgende keer even met een stevige borstel boenen. Wellicht dat het product dan beter intrekt?
John - 21 September 2015
Eerste klas
Al op meerdere paren nieuwe schoenen toegepast en zeer tevreden over het resultaat. Sportschoenen en sneakers blijven duidelijk schoner.
Product vraagt voor optimaal resultaat wel om wat hulp bij drogen door gebruik van een haarfohn
RedCat - 2 November 2014
Gtechniq
I1 Smart Fabric Coat Anti-Bacterial - 250 ml
  • Beschermt tegen vlekken op waterbasis
  • Ademend en extreem duurzaam
  • Dood bacteriën
  • Zeer hydrofoob
€ 20.99
Q²R Fabriccoat - 1000ml
  • Duurzame bescherming voor stof en textiel.
  • Geschikt voor interieur en exterieur gebruik.
  • Biedt duurzame UV bescherming tegen kleurverlies.
  • Verbruik: 80-100ml per m².
€ 175,-
Nearly sold out
Blogs about this product
