Powerful iron removal.
Removes even stubborn dirt
Q²M Iron dissolves industrial fallout, brake dust, and rail particles quickly and effectively. Even deeply embedded contamination is visibly removed, leaving your paint, wheels, and glass looking clean and smooth.
Safe for all surfaces.
pH-neutral and coating-friendly
Use Q²M Iron worry-free on paint, glass, wheels, and trim. The pH-neutral formula is gentle on surfaces and safe for ceramic coatings.
Visible results.
Color change shows it’s working
During use, Q²M Iron turns purple as it reacts with iron particles. This way, you can see exactly where the product is working – fast, effective, and without any guesswork.
Q²M Iron is one of the most powerful and fastest-working products for removing iron particles, industrial fallout, and brake dust. The advanced formula makes cleaning easier and delivers faster results for both enthusiasts and professionals.
Safe for paint, wheels, and glass
Use Q²M Iron on paint, wheels, trim, and glass. Thanks to its pH-neutral composition, it’s completely safe for all surfaces — even coated cars. It loosens even the most stubborn brake dust or deeply embedded grime.
During use, Q²M Iron changes color: the liquid turns purple as it reacts with iron particles, showing exactly where it’s working. The updated formula also has a milder scent, making it more pleasant to use.
Tip
Use Q²M Iron as part of your regular paint decontamination process, before claying or applying a protective layer. Always work on a cool surface and rinse thoroughly for the best results.
With Q²M Iron, you’ll remove contamination that regular washing can’t touch — for a visibly cleaner and smoother finish.
| Product number | GYIRO05 |
| Acid-free | Yes |
| Additives | Iron remover |
| Cleaning power | Strong |
| Colors Purple | Yes |
| Consistency | Liquid |
| Viscosity | Thin |
- Cool surface – Use in the shade, not on hot panels.
- Spray – Apply generously to paint, wheels, or glass.
- Wait – Let it work for 1–2 minutes. The liquid will turn purple.
- Optional brushing – Use a brush or cloth for stubborn dirt.
- Rinse – Rinse thoroughly with water. Done!
Topspul
Niet alleen voor velgen geschikt. Prima spul en inderdaad, niet meer zo ranzig ;-)
Fijne Iron remover en clay lube in 1
De geur is zeker een stuk aangenamer dan de vorige versie en dan andere iron removers. Ik gebruik het tijdens het kleien met een clay towel. Hierdoor doe ik 2 stappen in 1 en is de lak hierna super glad en schoon!
Topper
Werkt goed zoals het hoort Wel duur maar zuinig in gebruik
