Exterior
Fits your setup
Available with multiple connectors
The Monello Lancia Foam Lance is available with a wide range of connectors, making it compatible with almost any pressure washer. Whether you’re using a Kärcher K-Series, Nilfisk, Kränzle, Bosch or another popular brand, there’s a version that fits your machine perfectly. No need to struggle with universal fittings or complicated adapters—just choose the version that matches your setup and you’re good to go. Simple, efficient, and tailored to your detailing gear.
Foam party alert
Thick and clingy foam
What really sets this foam lance apart is the impressively thick foam it produces. By precisely mixing air, water and shampoo, it creates a creamy lather that clings to your vehicle’s surface. This helps to effectively loosen dirt and grime before you even touch the paint with a wash mitt. A proper pre-wash starts with a rich foam layer, and that’s exactly what the Monello Lancia delivers. It’s not just more effective—it also makes washing your car way more fun.
Tough and clever
Durable 1L bottle with measurements
The included 1-liter HDPE bottle is not only tough, but also cleverly designed. With a clear measurement scale on the side, it allows you to easily and accurately mix the right shampoo-to-water ratio. This helps avoid waste and ensures optimal foam every time. Made from high-quality HDPE material, the bottle is built to withstand strong chemicals and frequent use. Whether you're working with heavy-duty foams or gentle shampoos, this bottle is ready for the job.
Monello Lancia Foam Connector for Nilfisk pressure washers with the newer type of connector. With this attachment you can easily connect your lance to your Nilfisk pressure washer.
| Product number | MLLCNEW |
| Aansluiting | Nilfisk |
| Product type | Foamguns |
- The Lancia Foam Lance comes pre-installed with a 1.1 mm nozzle. If your pressure washer shuts off or stalls, switch to the included 1.25 mm nozzle. This can easily be done with a flathead screwdriver. You can see how to do this in the video below:
Changing the nozzle - Screw the chosen connector onto the foam lance. Hand-tight is sufficient. Depending on the connector used, make sure the wings are in the correct position so that the lance sits straight on the spray gun.
- Attach the included pickup tube under the red cap. This will draw the liquid during foaming.
- Fill the bottle with your foam mixture in the correct ratio, and use warm water for better blending.
- After use, rinse thoroughly with clean water. Remove the bottle and run clean water through the lance for at least 30 seconds to flush the internal filter.
Ja. De meshfilters zorgen voor het mengen van water, lucht en product om schuim te maken. Na verloop van tijd kunnen ze verstopt raken door residu, en dan kun je ze eenvoudig vervangen. Los verkrijgbaar.
Zeker. We hebben losse HDPE-flessen beschikbaar, zelfs met een dop zodat je mengsel schoon en lekvrij bewaard blijft.
Ja, alle foams werken met deze lans. De HDPE-fles is bestand tegen vrijwel alle reinigingsmiddelen en gaat veel langer mee dan PET-flessen.
- Een HDPE-fles (stevig, zuur- en zoutbestendig, scheurt niet)
- Betere stabiliteit, zodat hij niet snel omvalt
- Eenvoudig verstelbare straal (horizontaal of verticaal)
- Instelbare mengverhouding met de knop bovenop
Schitterende foamgun
Goeie foam, handig in gebruik en kwalitatief zeker in orde! Aanrader!
Top foam lance
Zeer handig in combinatie met mijn karcher. Even zoeken naar de juiste afstelling om de juiste combinatie water/schuim te bekomen maar verder loopt alles vlot.
Zeer tevreden van deze aankoop
Top foam lance
Echt een top ding, je kan m heel goed afstellen met een brede of smalle foam dekking. Is van goed sterk materiaal gemaakt en ziet er zeer degelijk uit. Wat een upgrade van mijn Kärcher foam gun. In samenwerking met de monello pistola een perfecte combi en zeer goede upgrade om je wagen wekelijks goed te wassen.
