- Soft microfiber towel
- 3-pack
- Ideal for wiping polish, wax and glass cleaners
Monello Peluche Verde Trio - Versatile softness for paintwork
This set consists of three high-quality microfiber towels known for their versatility. With a density of 350 GSM (grams per square meter), the Peluche Verde offers an excellent balance between softness and cleaning power. This makes the towels extremely suitable for wiping off polishing compounds, wax residues, and detailers, but they can also be safely used for interior cleaning.
The fiber structure ensures that dirt and residue are effectively absorbed and trapped, rather than being pushed around. The edges feature a soft, satin finish to minimize the risk of scratches. The 45x45cm size is slightly larger than standard, providing a comfortable working surface that handles well. While the towel is very soft, it may be less suitable for extremely sensitive paints compared to the heavier variants in the Monello line. Nevertheless, this is the ideal 'workhorse' towel for almost any detailing job.
| Product number: | MPV0103 |
| Gram per vierkante meter: | 350 |
- Size: 45x 45 cm
- 350 gsm
Fold the towel twice before use to create a manageable square with eight clean sides. Rub with light pressure over the surface to remove the residue of wax, polish, or spray. Once a side is saturated, flip the towel or refold it to a clean side for a streak-free result.
Tips Always wash new microfiber towels before first use to remove any loose lint from production. Do not use fabric softener, as this clogs the fibers and reduces absorbency.
1 - 3 of 63 reviews
Mooie doeken
Ik heb ze nog niet gebruikt wel alvast gewassen. Zien er keurig uit! Had misschien liever gehad dat ze apart verpakt waren ipv 3 in 1 zak volgende keer bestel ik losse zodat ik ze allemaal in een eigen zak heb voor afwisseling in de kofferbak.
Topper
Een fijne doek om polijstresidu mee af te nemen of om wax mee uit te poetsen. Neemt slecht vocht op, daarom gebruik ik liever andere doeken voor spray sealants.
Fijne doeken.
Bij één van de eerste bestellingen gekocht. Erg fijne doeken. Inmiddels al meerdere in de kast liggen, werken erg fijn met hun twee verschillende kanten.
Small but mighty
Compact and Handy
The Monello Peluche Verde microfiber towel, with its convenient size of 45x45 cm, is the perfect choice for car enthusiasts. Not too big, not too small, but just right for effortless cleaning. Its size makes it easy to handle, even in tricky areas like door frames and mirrors. At the same time, it offers enough surface area to work effectively without constant folding or repositioning. Additionally, the towel is available in an economical set of three, ensuring you always have enough on hand. Whether you’re a beginner or an experienced detailer, this towel seamlessly fits into your routine.
Wax on, polish off
Ideal for Wax and Polish
Thanks to its ultra-soft fibers, the Monello Peluche Verde is the perfect companion for removing waxes and polishes. The towel glides smoothly over surfaces, effortlessly picking up product residues without leaving scratches behind. The result? A brilliant, streak-free finish you can be proud of. Its high absorption capacity makes it ideal for removing excess product, leaving your paintwork looking sleek and shiny. You’ll be amazed at how quickly and efficiently it gets the job done.
This towel does it all
Great for Interior Use Too
This towel isn’t just great for the exterior of your car; it’s also a standout performer for interior cleaning. Use the Monello Peluche Verde to remove dust, fingerprints, and dirt from your dashboard, door panels, and other surfaces. Its soft texture ensures no damage while leaving your interior looking fresh and clean. Plus, it’s compact enough to store in your glove box or detailing kit, so you’re always ready for a quick touch-up. Truly a versatile tool!
