Raffino Forte Cutting Pad - 125mm
Art. nr. MRFP5
5.0 (7)
  • Een echte alleskunner
    Onze blauwe krokodil
Vertrouwde kwaliteit
Gemaakt in de VS
Wel zo handig
Beide zijdes tegelijkertijd
Goed gemaakt
Stevige nylon borstelharen
Monello Raffino Forte Cutting Pad - Restores paintwork with precision.
The Raffino Forte Cutting Pad is a polishing pad designed for dual-action polishers. This product is intended for removing deeper swirls and scratches, severe oxidation, and other significant paint defects. It can be used with medium and heavy polishing compounds. The firm foam breaks down the abrasive particles effectively and, especially for a coarse polishing pad, delivers an excellent finish, meaning very little follow-up work is required.
The foam has a slightly flared design, making the pad more stable on the paintwork and reducing deformation during polishing. The pad is 25 mm thick, features a cooling hole in the center, and comes in a resealable package so you can store it dust-free after use. Naturally, be sure to clean the pad thoroughly first and store it completely dry.
Product number MRFP5
Color Purple
Geschikt voor Ø steunschijf 125 mm
Polishing power Strong
Suitable for application Polishing, Scratch Repair
Suitable for type machine Excentric / Dual Action
Type polijstpad Foam
Center the pad as accurately as possible on the backing plate of the polishing machine. Apply a small amount of polish or compound to the surface of the foam. Work the product in evenly at a low to medium to high speed. Apply moderate pressure, depending on the product.
After polishing, wipe away the residue with a clean, high-quality microfiber towel.
Tips
  • Clean the pad regularly during use with warm water to prevent the buildup of product and dust.
  • Wash the pad immediately after use with warm water and a suitable pad cleaner or a small amount of dish soap. Do not wash in the washing machine, and do not leave to soak in water.
Een cutting pad is een harde, grove polijstpad. Je gebruikt hem om een flinke lakcorrectie uit te voeren. Denk hierbij aan het verwijderen van diepere krassen, hardnekkige swirls (waskrassen), zure vlekken van ingebrande vogelpoep en het herstellen van volledig doffe of verweerde laklagen.
Regelmatig! Tijdens het polijsten hoopt residu van polijstmiddel en verwijderde lak zich op in het foam. Als de pad verzadigd raakt, verliest hij zijn cutting-kracht en kan hij te warm worden. Maak de pad na elke 1 à 2 panelen schoon met een speciale padborstel of blaas hem uit met perslucht.
Voor een maximale lakcorrectie combineer je de Raffino Forte pad met een grove polijstpasta (compound), zoals de Monello Raffini Veloce. Deze combinatie geeft de nodige "bite" om snel en effectief krassen uit zelfs de hardste lakken (zoals bij Duitse auto's) te polijsten.
De Raffino Forte is de directe opvolger van de bekende gele Raffini cutting pad. Monello heeft deze vernieuwde paarse pad voorzien van een verbeterde foamstructuur. De pad behoudt zijn hoge cutting-kracht langer, voert warmte efficiënter af en is nóg duurzamer in gebruik op excentrische polijstmachines.
Super
Superfijne krachtige en stevige pad die met gemak krassen verwijdert. Ook voorzien van koelgat in het midden om oververhitting te voorkomen.
Charles - 5 November 2026
De nieuwe standaard
Als onderdeel van het Carclean testpanel heb ik de nieuwe serie pads flink mogen uittesten. De pads zijn in kwaliteit nu van het kaliber Scholl, Gyeon, Rupes etc. Ze zijn onverwoestbaar door de nieuwe verlijming. Het is tevens makkelijk om mee te werken. Wat ook fijn is, in het vele kleuren tijdperk, dat je op de achterkant in een keer ziet met welke pad je te maken hebt. Deze cutting pad heeft voldoende 'bite'
Slome - 28 June 2026
Fijne pad
Zeker een fijne pad geworden, weer een stapje beter dan de oude monello pads. Net wat dikker, betere kwaliteit foam. Echt een aanrader.
Van Helvert - 27 June 2026
Offer
Q²M Heavy Cut Pad Eccentric
  • Heavy cut pad voor het aanpakken van diepere lakdefecten
  • Speciaal ontworpen voor excentrische (Dual Action-) machines
  • Verkrijgbaar in twee formaten: 80mm en 145mm
  • Perfect voor gebruik met Q²M Compound(+)
Retail price: € 17.99 € 9.99
Offer
Rupes
D-A Coarse Cutting Foam Pad - Diverse maten
  • Grove polijstpad voor lichte tot zware lakcorrectie
  • Geschikt voor medium tot zware polijstmiddelen
  • Individueel verpakt in flow pack
  • Werkt het beste i.c.m. Rupes D-A Coarse Compound
Retail price: € 13.13 € 9.99
Koch-Chemie
Heavy Cut Foam Pad
  • Removes deep scratches
  • Stable and comfortable
  • Long service life
  • High cutting factor
  • € 15.51
    Nearly sold out
    Menzerna
    Heavy Cut Pad - Diverse afmetingen
    • Heavy Cut polijstpad
    • Trapezevormige pad voor een optimaal contactoppervlak
    • Hoge kwaliteit klittenband
    • Verkrijgbaar in verschillende maten
    € 22.99
    Scholl Concepts
    Medium Cutting Pad - 50 mm - 2-pack
    • Medium cutting pad
    • 50 mm
    • 2 pack
    € 8.99
    Blogs about this product
