Raffino Forte Cutting Pad - 75mm
Art. nr. MRFP3
5.0 (7)
  • Een echte alleskunner
    Onze blauwe krokodil
Vertrouwde kwaliteit
Gemaakt in de VS
Wel zo handig
Beide zijdes tegelijkertijd
Goed gemaakt
Stevige nylon borstelharen
Monello Raffino Forte Cutting Pad - Restores paintwork with precision.
The Raffino Forte Cutting Pad is a polishing pad designed for dual-action polishers. This product is intended for removing deeper swirls and scratches, severe oxidation, and other significant paint defects. It can be used with medium and heavy polishing compounds. The firm foam breaks down the abrasive particles effectively and, especially for a coarse polishing pad, delivers an excellent finish, meaning very little follow-up work is required.
The foam has a slightly flared design, making the pad more stable on the paintwork and reducing deformation during polishing. The pad is 25 mm thick, features a cooling hole in the center, and comes in a resealable package so you can store it dust-free after use. Naturally, be sure to clean the pad thoroughly first and store it completely dry.
Product number MRFP3
Color Purple
Geschikt voor Ø steunschijf 70 - 75 mm
Polishing power Strong
Suitable for Bumpers, Dorpels, Mirrors, Motor cycles, Raamstijlen, Wheel and door shuts
Suitable for application Polishing, Scratch Repair
Suitable for type machine Excentric / Dual Action
Type polijstpad Foam
Center the pad as accurately as possible on the backing plate of the polishing machine. Apply a small amount of polish or compound to the surface of the foam. Work the product in evenly at a low to medium to high speed. Apply moderate pressure, depending on the product.
After polishing, wipe away the residue with a clean, high-quality microfiber towel.
Tips
  • Clean the pad regularly during use with warm water to prevent the buildup of product and dust.
  • Wash the pad immediately after use with warm water and a suitable pad cleaner or a small amount of dish soap. Do not wash in the washing machine, and do not leave to soak in water.
Een cutting pad is een harde, grove polijstpad. Je gebruikt hem om een flinke lakcorrectie uit te voeren. Denk hierbij aan het verwijderen van diepere krassen, hardnekkige swirls (waskrassen), zure vlekken van ingebrande vogelpoep en het herstellen van volledig doffe of verweerde laklagen.
Regelmatig! Tijdens het polijsten hoopt residu van polijstmiddel en verwijderde lak zich op in het foam. Als de pad verzadigd raakt, verliest hij zijn cutting-kracht en kan hij te warm worden. Maak de pad na elke 1 à 2 panelen schoon met een speciale padborstel of blaas hem uit met perslucht.
Voor een maximale lakcorrectie combineer je de Raffino Forte pad met een grove polijstpasta (compound), zoals de Monello Raffini Veloce. Deze combinatie geeft de nodige "bite" om snel en effectief krassen uit zelfs de hardste lakken (zoals bij Duitse auto's) te polijsten.
De Raffino Forte is de directe opvolger van de bekende gele Raffini cutting pad. Monello heeft deze vernieuwde paarse pad voorzien van een verbeterde foamstructuur. De pad behoudt zijn hoge cutting-kracht langer, voert warmte efficiënter af en is nóg duurzamer in gebruik op excentrische polijstmachines.
prima pad
dikke stevige pad die met klittenband op de steunplaat wordt geplaatst. Door de dikte kun je bij een auto met randen en rondingen beter poetsen dan met de oude wat dunnere pad.
Komt goed los na gebruik en is prima te reinigen.
Martijn - 26 June 2026
Prima pad
Stevige polijstpad. Corrigeert goed icm zwaardere polijstmiddel. De pad is vrij hoog t.o.v. andere pads. Kan even wennen zijn. Maar heeft ook voordelen met bepaalde rondingen en randen van een auto. De velcro kleeft super goed aan de steunplaat vast. Dus met beleid verwijderen. Verder niks op aan te merken.
Roy - 25 June 2026
Lekker stevge pad
Deze cutting pad is echt stevig maar wel met een meer open structuur. Polijstmiddel kan er wat dieper intrekken tijdens gebruik en warm worden dus spoel deze op tijd uit om gumming te voorkomen.
De pad blijft zeer goed zitten op de klittenband van diverse machines, dit is gewoon een heel erg goede cutting pad.
Ook vind ik de kleur mooi, het toch vaak witte polijstmiddel is erg goed zichtbaar, handig met schoonmaken.
Michel - 25 June 2026
Offer
Q²M Heavy Cut Pad Eccentric
  • Heavy cut pad voor het aanpakken van diepere lakdefecten
  • Speciaal ontworpen voor excentrische (Dual Action-) machines
  • Verkrijgbaar in twee formaten: 80mm en 145mm
  • Perfect voor gebruik met Q²M Compound(+)
Retail price: € 17.99 € 9.99
Offer
Rupes
D-A Coarse Cutting Foam Pad - Diverse maten
  • Grove polijstpad voor lichte tot zware lakcorrectie
  • Geschikt voor medium tot zware polijstmiddelen
  • Individueel verpakt in flow pack
  • Werkt het beste i.c.m. Rupes D-A Coarse Compound
Retail price: € 13.13 € 9.99
Koch-Chemie
Heavy Cut Foam Pad
  • Removes deep scratches
  • Stable and comfortable
  • Long service life
  • High cutting factor
  • € 15.51
    Menzerna
    Heavy Cut Pad - Diverse afmetingen
    • Heavy Cut polijstpad
    • Trapezevormige pad voor een optimaal contactoppervlak
    • Hoge kwaliteit klittenband
    • Verkrijgbaar in verschillende maten
    € 22.99
    Scholl Concepts
    Medium Cutting Pad - 50 mm - 2-pack
    • Medium cutting pad
    • 50 mm
    • 2 pack
    € 8.99
    Blogs about this product
