Bold N Bright Gel - 473ml
Art. nr. PB-BNBG16
Poorboy's World Bold N Bright Tyre Gel - Restore the deep black color of tires.
Poorboy's World Bold N Bright Tyre Gel is a gel-based tire dressing that nourishes the rubber and provides a dark, rich shine. This thick consistency allows for very precise application, effectively preventing overspray or splatters on the car paint. The water-based formula absorbs quickly and leaves absolutely no sticky or greasy layer behind. As a result, new road dirt does not get a chance to quickly adhere to the treated surface.
This gel is safe to use on all types of car tires and rubber trim. The product contains special UV blockers that prevent the rubber from further drying out or turning brown due to harmful sunlight. Because the gel penetrates deep into the rubber, the material remains soft and supple. The gel works excellently to create a subtle gloss without making the tires look unnatural.
Product number: PB-BNBG16
Consistency: Gel
  1. Ensure a dry and thoroughly cleaned tire surface.
  2. Apply a small amount of gel onto a dedicated applicator pad.
  3. Spread the product in an even layer across the sidewall of the tire.
  4. Wipe off any excess residue with a clean microfiber towel.
Tips
  • Buff the rubber with a clean towel immediately after application for a subtle satin gloss.
  • Apply a second layer after an hour for an extra dark and striking finish.
1 - 3 of 15 reviews
Toppie
Ik gebruik dit icm de tire brush van Sonax. Perfecte combinatie !
TONY - 07/05/2026
Fijn product
Glimt niet overdreven. Makkelijk aan te brengen. Ik gebruik een goedkoop sponsje uit de winkel die ik na gebruik weggooi om het product aan te brengen.
Bryan - 25/01/2025
fijn spul
Is met microvezel spons , fijn op te brengen en banden zien er super uit. Enigste minpunt en verbeterpunt vind ik de houdbaarheid na dag of 3 zie je niet zo veel meer, en bij regen bijna gelijk weg.
Bert - 27/07/2024
Poorboys World
Bold N Bright Tire Dressing - 473ml
  • Water-based car tire dressing
  • Non-greasy and non-sticky
  • Protects against UV radiation
  • Zero paintwork sling effect
€ 21.99 € 19.99
Stjärnagloss
  • Satijnen afwerking
  • Geen uitlopers of vlekken
  • Prettige geur
€ 19,-
Nearly sold out
Offer
Dodo Juice
Dark Matter Trim and Tyre Dressing
  • Kunststof- en bandendressing
  • Geeft een satijnen finish
  • Geen uitlopers in de regen
  • Gemakkelijk in gebruik
€ 18.99
Temporarily unavailable
Get stock notification
