Bold N Bright Gel - 473ml
Art. nr. PB-BNBG16
Poorboy's World Bold N Bright Tyre Gel - Restore the deep black color of tires.
Poorboy's World Bold N Bright Tyre Gel is a gel-based tire dressing that nourishes the rubber and provides a dark, rich shine. This thick consistency allows for very precise application, effectively preventing overspray or splatters on the car paint. The water-based formula absorbs quickly and leaves absolutely no sticky or greasy layer behind. As a result, new road dirt does not get a chance to quickly adhere to the treated surface.
This gel is safe to use on all types of car tires and rubber trim. The product contains special UV blockers that prevent the rubber from further drying out or turning brown due to harmful sunlight. Because the gel penetrates deep into the rubber, the material remains soft and supple. The gel works excellently to create a subtle gloss without making the tires look unnatural.
Product number: PB-BNBG16
Consistency: Gel
  1. Ensure a dry and thoroughly cleaned tire surface.
  2. Apply a small amount of gel onto a dedicated applicator pad.
  3. Spread the product in an even layer across the sidewall of the tire.
  4. Wipe off any excess residue with a clean microfiber towel.
Tips
  • Buff the rubber with a clean towel immediately after application for a subtle satin gloss.
  • Apply a second layer after an hour for an extra dark and striking finish.
Nee, absoluut niet. In tegenstelling tot veel andere dikke bandendressings is ook deze Gel volledig geformuleerd op waterbasis. Het bevat geen vette siliconen. De gel trekt volledig in de poriën van het rubber en droogt "droog" op. Hierdoor plakt er geen straatvuil of zand aan je banden.
Omdat een gel diep in de poriën van het rubber wil dringen, moet de weg vrij zijn. Als er nog oude, vette siliconenlagen of bruine vuilafzetting op de band zit, kan de gel niet hechten en zal hij sneller slijten. Een schone, ontvette ondergrond zorgt ervoor dat de gel tot wel 3 tot 4 weken perfect blijft zitten.
De Gel heeft een veel dikkere, rijkere substantie. Hierdoor laat het zich uitermate nauwkeurig verwerken met een applicatorpad zonder dat het drupt op je schone velgen. Daarnaast is de Gel-formule iets geconcentreerder, wat zorgt voor een diepere voeding van het rubber en een langere standtijd.
A high-quality tyre gel that restores deep, natural black with a subtle satin sheen. Easy to apply with a sponge, brush or applicator; works well on new and used tyres. Consistently praised for finish and ease of use—preferred by many detailing enthusiasts.
4 - 3 of 15 reviews
Net een voldoende. Bij droog weer blijft het niet lang (max week) erop. Wel mooie zijdeglans.
Omer Ozdemir - 29/04/2014
Eerste klas
Dit spul al enkele maanden geleden aangeschaft. Persoonlijk vind ik het produkt tegenvallen, na enkele malen in de regen te hebben gereden blijft er van de glans niks meer over. Nochtans eerst de banden goed ontvet met apc.
Marc Vanvaerenbergh - 23/03/2013
Super spul ! Makkelijk op te brengen en een super uitstraling
Raymond Weijts - 12/02/2013
Poorboys World
Bold N Bright Tire Dressing - 473ml
  • Water-based car tire dressing
  • Non-greasy and non-sticky
  • Protects against UV radiation
  • Zero paintwork sling effect
€ 19.99
Temporarily unavailable
Get stock notification
Stjärnagloss
  • Satijnen afwerking
  • Geen uitlopers of vlekken
  • Prettige geur
€ 19,-
Dodo Juice
Dark Matter Trim and Tyre Dressing
  • Kunststof- en bandendressing
  • Geeft een satijnen finish
  • Geen uitlopers in de regen
  • Gemakkelijk in gebruik
€ 18.99
Bold N Bright Gel - 473ml in our blog
