Ultra Glaco Glass Sealant - 70ml
Art. nr. 04146
5.0 (35)
  • For crystal-clear windows in any storm
    A must-have for your car windows
Rain dance? We'd rather not.
Superior Water Repellency
Ultra Glaco creates an invisible yet incredibly strong water-repellent coating on your car windows. Thanks to advanced Fusso technology, rainwater beads off the glass as soon as you reach 45–60 km/h. Your visibility remains clear, even during heavy downpours, which is not only more comfortable but also safer. This coating actively repels rain, snow, dirt, and even ice formation, keeping your windows much cleaner and reducing the need to use your wipers as often.
Kleding, Handschoen, E-scooter, vervoer, Voertuig
Handschoen, Volwassene, Mannelijk, Man, Persoon
Long live Glaco!
Lasts up to 12 months
Forget about reapplying glass coating every month. Ultra Glaco remains effective on your car windows for up to a year, even under harsh weather conditions or frequent washes. The coating bonds firmly to the glass surface and withstands wipers, cleaning agents, and UV radiation. This means less maintenance and year-round crystal-clear visibility. Apply once, enjoy for a year.
Click, twist, apply!
Convenient All-in-One Application
Ultra Glaco isn’t just effective—it’s also super easy to use thanks to the built-in felt applicator. No hassle with cloths, pads, or separate bottles—just twist off the cap and apply the product directly to the window. The felt surface ensures an even distribution of the coating, without mess or streaks. This makes application quick and effortless, even for beginner detailers. Perfect for those who want both convenience and great results.
Soft99 Ultra Glaco is a powerful glass coating that protects your car windows for up to 12 months against rain, dirt, and ice. Utilizing advanced Fusso technology, it forms a durable, water-repellent layer resistant to wipers, car washes, and cleaning agents.
The integrated felt applicator makes application easy and clean. At speeds of 45-60 km/h, Ultra Glaco causes water to bead off the windshield, enhancing visibility during rainy drives. It also simplifies the removal of insect residues and ice in winter.
For optimal results, it's recommended to thoroughly clean the glass beforehand using a dedicated glass cleaner like Glaco Glass Compound Roll On.
Product number 04146
Consistency Liquid
Durability Long
Product form Squeeze bottle
Suitable for glass Yes
Suitable for material Glass
Volume Small (0 - 400ml)
  1. Wash the windows thoroughly and make sure they are completely dry. If necessary, use a glass polish like Glaco Glass Compound Roll On.
  2. Shake the bottle well with the cap on.
  3. Remove the cap and press the felt applicator onto the dry glass. Gently squeeze the bottle to release the product and apply it evenly using a crosshatch motion.
  4. Allow the product to dry for 5–10 minutes until a white haze appears.
  5. Wipe away the haze with a clean, dry microfiber cloth.
  6. Keep the glass dry for at least 12 hours to allow the coating to fully cure.
Met één verpakking Ultra Glaco kun je ongeveer 4 tot 5 auto’s volledig behandelen (voorruit, zijruiten en achterruit). Natuurlijk hangt het af van de grootte van je auto en hoe royaal je het aanbrengt.
Gebruik een pluisvrije glasdoek of een schone microvezeldoek die geschikt is voor glas. Daarmee voorkom je vlekken of strepen, en houd je het zicht perfect helder.
Laat het minimaal 12 uur droog blijven na het aanbrengen. Geen regen, geen ruitenwissers, en liever ook niet rijden. Zo krijgt de coating de kans om goed uit te harden – en dat is cruciaal voor een langdurig effect.
Reinig de ruiten grondig met een speciale glasreiniger zoals Glaco Glass Compound Roll On. Zo hecht de coating beter en gaat ‘ie langer mee.
Nee, liever niet. Op spiegels krijg je wel ‘beading’ (druppelvorming), maar daar is geen rijwind om de druppels weg te blazen. Het resultaat? Een wazig zicht. Gebruik liever een specifieke coating voor spiegels of laat ze onbehandeld.
Vanaf zo’n 45-60 km/u parelt regenwater vanzelf van je ruit af – je hebt dus vaak nauwelijks ruitenwissers nodig. Ook insectenresten en ijs verwijder je makkelijker dankzij de gladde coatinglaag.
SOFT99 Corporation
Tanimachi 2-6-5
540-0012 Osaka, Japan
Soft99 Europe
ul. Kramarska 3/5
61-765 Poznań, Polen
Beste glascoating
Wederom voor tweede keer besteld, in mijn ogen de beste coating voor op glas. Gebruik dit ook op de ruiten van de douchecabine en water loopt er af.
Als je de coating op de ramen hebt hoef je bijna nooit meer de ruitenwissers te gebruiken en je kijkt makkelijk tussen de druppels door. Een must voor elke detailer!
Stefan - 26 October 2024
Beste glass coating op de markt
Meerdere glass coatings verder maar deze is echt een aanrader, zeer gemakkelijk aan te brengen in combinatie met Glaco Glass compound Roll on die je glas echt helemaal glad en als nieuw maakt.
Als het regent heb je de ruitenwissers niet eens nodig!
Menno - 7 July 2024
Goed product.
Heb het vorige week eerste maal gebuikt. Op mijn rit naar Kroatië veel regen gehad. Ruitenwisser minimaal moeten gebruiken. Zijruiten blijven echt volledig zuiver. Echt aan te raden.
Jean-Pierre - 25 April 2024
