- Nylon/ microvezel interieur pad
- Geschikt voor het reinigen van vrijwel elk interieur oppervlak
- Garandeert een diepe reiniging van het oppervlak
With the Scrub Ninja, you can effortlessly achieve a thorough clean for your car’s interior. This versatile scrubbing pad is suitable for a wide range of materials, including plastic, leather, vinyl, and upholstery. Thanks to its firm yet soft fibers, it easily reaches deep into the contours and seams of surfaces, effectively removing even the toughest dirt.
The Scrub Ninja is designed with two distinct sides for optimal performance. The white side, made of durable nylon, is ideal for tackling stubborn stains and grime. Meanwhile, the gray side, crafted from high-quality microfiber, functions as a small, integrated cleaning cloth. This side is perfect for gently cleaning and polishing delicate surfaces, ensuring a quick and streak-free finish.
Flexible and Easy to Use
What truly sets the Scrub Ninja apart is its flexibility. You can easily fold it, allowing you to clean even the trickiest corners and tight spaces with ease. Where a cloth is often too large and slips around, and a brush is too rigid, this scrub pad strikes the perfect balance between precision and ease of use. Additionally, the microfiber side acts as a convenient small cloth, always at hand, making your cleaning tasks even more efficient.
Important Note
The white nylon side is not suitable for use on high-gloss surfaces, as it may cause scratches. For such surfaces, use only the soft microfiber side to protect the finish and achieve a glossy, flawless result.
Price per piece
| Product number: | SN-SFLAT |
- Formaat: 13 x 9 cm
- Materiaal: 75% Polyester/ 25% Polyamide
LET OP: De witte zijde is NIET geschikt voor hoogglans oppervlakken.
Dit hangt af van het gebruik, maar ze zijn zeer duurzaam. Gemiddeld kun je er tientallen auto-interieurs mee reinigen. Zodra de nylon borstelharen plat gaan liggen of de microvezel verzadigd raakt met vuil dat er niet meer uitgaat, is het tijd voor een nieuwe.
Gebruik de Scrub Ninja altijd vochtig of in combinatie met een vloeibare reiniger. Dit zorgt voor smering, waardoor het vuil makkelijker loslaat en de kans op wrijving-schade aan het oppervlak wordt geminimaliseerd.
Je kunt hem na gebruik uitspoelen met warm water en een milde zeep. Bij sterke vervuiling kan hij in de wasmachine (max. 40°C) met een specifiek microvezel wasmiddel. Gebruik nooit wasverzachter en stop hem niet in de droger.
Ja, de Scrub Ninja is een hulpmiddel (tool), geen reinigingsmiddel. Gebruik het in combinatie met een interieurreiniger of leerreiniger voor het beste resultaat.
1 - 3 of 6 reviews
Must have
Ideaal voor wat meer vervuilde delen van het interieur. Bijv stuur en zetels, even schrobben en afnemen! Ook makkelijk voor dorpels en deuren.
Werkt super
Werkt super om alles binnenin de auto te wassen, zowel plastic als leder. Aan te raden
Fijne scrub pad, helaas zwart
Hele fijne pad, uitstekend voor het dashboard, samen met KC pol star gebruikt. Grondig en veel sneller klus geklaard. Enige minpunt vind ik dat de nylon zijde zwart is, i.p.v. wit. Daardoor kan je niet zien hoe vies de pad is en loop je kans dat je met een te vuile pad bezig bent.
De scrubpad met een dubbele persoonlijkheid
Twee kanten, dubbel zo handig
De Scrub Ninja is uitgerust met twee unieke zijden, elk ontworpen voor een specifieke taak. De witte zijde, gemaakt van stevig nylon, is je beste vriend bij het aanpakken van hardnekkige vlekken en vuil. Of het nu gaat om modderspetters op de deurpanelen of opgedroogde koffievlekken op de bekleding, deze kant klaart de klus. De grijze zijde daarentegen is vervaardigd van zachte microvezel en werkt als een kleine geïntegreerde doek. Hiermee geef je oppervlakken de finishing touch, waarbij je voorzichtig reinigt en tegelijkertijd een streeploos resultaat achterlaat. Met deze veelzijdigheid in één compacte tool, heb je altijd precies wat je nodig hebt.
Deze ninja laat niets liggen
Geschikt voor elk oppervlak
De Scrub Ninja blinkt uit in veelzijdigheid en is geschikt voor vrijwel elk oppervlak in je auto-interieur. Of je nu kunststof deurpanelen, leren bekleding, stoffen zittingen of een vinyl dashboard wilt reinigen, deze scrubpad doet het allemaal. Dankzij zijn slimme ontwerp kun je hem veilig gebruiken zonder dat je bang hoeft te zijn voor beschadigingen (let wel: gebruik de nylon kant niet op hoogglans oppervlakken). Je hoeft niet langer te schakelen tussen verschillende schoonmaakmiddelen of tools; de Scrub Ninja is dé allrounder die je nodig hebt voor een complete schoonmaakbeurt.
De ninja die vuil te grazen neemt
Diepe reiniging, moeiteloos schoon
Met de Scrub Ninja bereik je een diep niveau van reiniging, zelfs op plekken waar traditionele tools tekortschieten. De flexibele schrobspons buigt gemakkelijk mee, zodat je in de kleinste hoekjes en kieren komt. De vezels van de spons dringen door tot in de contouren van stoffen en materialen, waardoor vuil, stof en vlekken effectief worden verwijderd. Waar een doek te groot is en een borstel te stijf, combineert deze pad precisie met kracht. Het resultaat? Een fris en grondig gereinigd interieur zonder dat je er veel moeite voor hoeft te doen.
