Washing and drying
Five Practical Tips to Effectively Remove Road Salt from Your Car
By: Dennis 4 min read
Once the snow melts, road salt remains. These five practical tips help you prevent damage and get your car safely clean after winter conditions.
Finally, the snow and ice are gone. But that doesn’t mean your car is automatically free of winter residues. Road salt, wet dirt, and other winter mess often remain stubbornly on the paint, wheels, and especially the lower parts of the car. And those are exactly the areas where you don’t want corrosion or damage to appear. With a little extra care and the right approach, you can prevent a lot of trouble. Below, we share five simple tips to safely and effectively remove road salt—no advanced math required.
Tip 1.
Use cold or at most lukewarm water
It might sound counterintuitive, especially if your hands already feel frozen, but hot water is not a good idea for road salt. Salt becomes more active when it comes into contact with heat, which means it can work more aggressively on paint, wheel arches, and other vulnerable parts of your car. Cold or lightly lukewarm water is the safest choice. Less comfortable for your hands, perhaps, but much gentler on your car.
Detailing Tip: Use gloves while washing in colder months. This helps you last longer without the urge to reach for hot water.
Tip 2.
Always start with a proper prewash
Before you even think about contact washing, you want to loosen as much dirt as possible. A prewash is perfect for this and isn’t just for summer insects. Winter grime is often coarser and greasier. In this case, Bilt-Hamber Touch-Less is an excellent choice. This snow foam has extra cleaning power and is specially designed for heavier contamination like road salt. It adheres well to the surface, has time to do its job, and prevents unnecessary scrubbing later.
Detailing Tip: Always let the foam dwell for a while, but avoid letting it dry. Especially in cold, windy conditions, it can happen faster than you think.
Bilt-Hamber
Touch-Less Snow Foam - 1000ml
  • Zeer effectieve prewash foam
  • Geschikt voor foamlans, handfoamers en zelfs sprayers
  • Biologisch afbreekbaar
  • Gemiddelde PIR van 1%
€ 16.99
In stock
AVA
Evolution series P60 145 bar hogedrukreiniger - L-pack
  • Uitgebreide, krachtige hogedrukreiniger
  • Geleverd met diverse hulpstukken en met staal versterkte slang
  • 145 bar/500 liter per uur
  • Aluminium pomp met 4 cilinders
€ 389,-
Has been discontinued
Tip 3.
Rinse with a pressure washer
After letting the prewash work, it’s time to rinse everything thoroughly. You can use your own pressure washer or just a wash bay. With heavy contamination, this makes a world of difference. Without touching the car, you can already rinse away a large portion of the dirt. The difference between treated and untreated areas is often immediately visible, and that without using a single wash mitt.
Detailing Tip: Always work from top to bottom when rinsing. This prevents dirt from running over already clean areas.
Tip 4
Give extra attention to the lower parts
The lower parts of your car take the hardest hit during winter. Think sills, wheel arches, the rear, and the undersides of bumpers. These areas collect not only road salt but also sand and mud. They require extra attention during washing. Work carefully and make sure to clean these zones, but only after most of the dirt has already been removed.
Detailing Tip: Rinse wheel arches thoroughly. Road salt often hides here, making it a prime spot for rust to develop.
Tip 5.
Protect your car with a spray sealant
After washing, protection is essential, especially in the cold winter months. Monello Acquafobia is a powerful spray sealant that’s easy to apply and provides 6 to 12 weeks of protection. The product creates a water- and dirt-repellent layer, making it harder for new dirt to stick. Perfect if you don’t want to wash extensively every week during winter.
Detailing Tip: Apply Acquafobia on a clean, wet car and rinse immediately. This ensures quick, even results without any hassle.
Acquafobia - 500ml
  • Easy to use spraycoating
  • Sustainable up to 12 weeks
  • Extremely water repellent
Retail price: € 16,- € 14,-
In stock
In short
Removing road salt isn’t rocket science, but it does require a little extra care. By making smart use of cold water, a strong prewash, and proper protection, you can prevent unnecessary damage. The difference between a half-cleaned car and one that’s truly winter-proof is immediately visible.
We hope this blog has helped get you started so you can safely tackle road salt—and soon you’ll be a true CleanRider too.
Skip product gallery
Bilt-Hamber
€ 16.99
In stock
Offer
Acquafobia - 500ml
In stock
Last chance
AVA
€ 389,-
Read more
By: Vincenth
