Lime Prime Fine Cut Prep Polish - 500ml
Mirror, mirror on the wall...
A deep gloss that dazzles
Dodo Juice Lime Prime is renowned for creating a truly excellent deep gloss finish that elevates your car's paintwork to the next level. Thanks to its unique blend of fine micro-abrasives and cleaning oils, light imperfections and oxidation are effortlessly removed, allowing the true color depth of the paint to resurface. The result is a surface that not only looks incredibly wet and shiny but also offers a reflection so sharp you could practically shave in it. Whether you have a dark or light-colored vehicle, this polish provides that coveted 'wet-look' that makes every car enthusiast’s heart skip a beat and turns heads at every corner.
The red carpet for your carnauba
The perfect foundation for any wax
This product serves as the absolute perfect preparation for any wax layer, but it is specifically optimized for the famous Dodo Juice carnauba waxes. By cleaning the surface both chemically and mechanically, Lime Prime ensures optimal bonding, meaning the subsequent wax layer not only shines better but also lasts significantly longer. It removes old wax residues and contaminants that a regular wash leaves behind, allowing the natural oils in the carnauba wax to perform at their peak. It is the crucial link in your detailing process that marks the difference between a simple wash and a professional showroom finish that protects your investment for weeks.
Stingier than a billionaire with a coupon
Extremely economical to use
What truly sets Dodo Juice Lime Prime apart from the competition is that it is extremely economical in use. You only need a few small, pea-sized drops to effectively treat an entire panel, which means the 500ml bottle lasts a surprisingly long time. The formula spreads incredibly easily across the paintwork, preventing you from using unnecessary amounts of product to achieve an even result. This not only makes it a sustainable choice for your wallet but also ensures you spend less time buffing away excess residue. A small investment in this bottle pays for itself many times over across countless detailing sessions, making it a staple in any serious kit.
Before applying a wax or sealant, you want to prepare the surface as thoroughly as possible. Pre-wax cleaners remove contamination from the paint’s pores, water spots, light oxidation, and swirls. Using a machine for application significantly enhances these corrective properties.
Dodo Juice Lime Prime is exactly such a product, even winning 'Polish Product of the Year' when it was first released. It is perfect for both manual and machine application, and a little bit of product goes a long way.
Lime Prime utilizes very fine abrasives that carefully prepare the paintwork to be finished with your choice of wax or sealant. As you might expect from its name, Lime Prime has a refreshing lime scent.
The high-quality fine abrasives make this product perfect for almost all modern high-gloss medium to hard paints—think of German and French cars, for example. For classic and Japanese cars, Critical Finish is often a better choice, as these paints tend to be very soft and sensitive.
Finally, it is important to realize that Lime Prime (or any pre-wax product) is perfect if you want to extract the maximum amount of gloss from your paintwork before applying a wax or sealant. If your goal is maximum durability and gloss is slightly less important, we recommend degreasing the paintwork after using Lime Prime to maximize the lifespan of your wax or sealant.
| Product number | DJLP500 |
| Additional features | Glossy |
| Finishing gloss level | High |
| Polishing power | Mild |
1. Voorbereiding
- Wassen: Zorg dat de auto grondig is gewassen en gedroogd.
- Kleien (optioneel): Voor het allergladste resultaat is het aan te raden de lak vooraf te behandelen met een detailklei om vastzittend vuil te verwijderen.
- Omgeving: Werk bij voorkeur in de schaduw en op een koel oppervlak.
2. Handmatige verwerking
- Aanbrengen: Doe 2 tot 3 druppels ter grootte van een erwt op een microfiber- of foam applicator pad.
- Inwerken: Breng het product aan op een klein oppervlak (ongeveer 40x40 cm). Maak overlappende, cirkelvormige of rechte bewegingen met lichte druk.
- Controleren: Blijf werken totdat er een dunne, olieachtige waas achterblijft. Laat het product niet volledig opdrogen op de lak.
3. Machinale verwerking (Dual Action polijstmachine)
- Pad keuze: Gebruik een zwarte of witte (finishing/light polishing) pad.
- Dosering: Breng 3 of 4 druppels aan op de pad.
- Snelheid: Verspreid het product op een lage stand over het vlak. Verhoog de snelheid naar een medium stand (bijv. stand 3 of 4) en maak langzame banen met lichte druk.
- Finish: Werk het door tot de waas nagenoeg transparant wordt.
4. Afnemen en nabehandelen
- Uitpoetsen: Gebruik een schone, zachte microvezeldoek om het residu direct af te nemen. Doe dit paneel voor paneel.
- Beschermen: Breng direct na het gebruik van Lime Prime je favoriete wax (bijvoorbeeld van Dodo Juice) of sealant aan voor een langdurige bescherming.
Ja! Zoals bijna alle producten van Dodo Juice heeft Lime Prime een heerlijke, kenmerkende geur. Dit maakt het werken aan je auto niet alleen effectief, maar ook een stuk aangenamer.
Je gebruikt Lime Prime na het wassen en kleien van de auto, maar vóór het aanbrengen van de wax. Het verwijdert de laatste restjes vervuiling die klei niet wegkrijgt en zorgt ervoor dat de lak weer volledig glad aanvoelt.
Nee, Lime Prime bevat geen beschermende bestanddelen. Het laat een schoon, glanzend oppervlak achter dat rijk is aan oliën, maar dit moet je altijd "opsluiten" met een goede wax of sealant. Het is de perfecte voorbereiding voor bijvoorbeeld de Dodo Juice Hard Candy of Blue Velvet wax.
Dat kan allebei. Met de hand gebruik je een microvezel of foam applicator om de lak te reinigen en glans te herstellen. Gebruik je een excentrische polijstmachine (Dual Action)? Dan kun je met een lichte finishing pad nog effectiever lichte swirls en krassen verwijderen.
Het is beide! Lime Prime is een lakreiniger (cleaner) die milde schuurmiddelen (abrasives) bevat. Het verwijdert oxidatie, watervlekken en lichte waskrassen (swirls), terwijl de natuurlijke oliën de lak voeden voor een diepe, "natte" glans. Het bereidt de lak optimaal voor zodat een wax beter hecht.
lime prime reinigt en geeft extra diepte,eerste maal gebruikt en een echte meevaller!TOP
Super spul de auto wordt nog gladder en en de wax is nog makkelijker aan te brengen. Gewoon paneel per paneel easy on easy off. Dankzij de top service van Carclean als Kado de Bleu Roo polishing pouch erbij gehad dit is wel een mast have als je het met de hand aanbrengt.
Werkt mooi op mijn rotary en geeft diepe glans. Hele lichte krasjes haalt het weg, maar stel hier niet teveel van voor. Ideaal dus als je een lage cutting factor wilt hebben. Tov PB. SSR1 -die in mijn ogen het zelfde doet- wel wat aan de hoge prijs.
