Detail Wheel Brush Large
Art. nr. EZ-BRUSH-L
EZ Detail EZ Detail Brush Large - The ultimate wheel brush
The EZ Detail Brush Large is the bigger brother of the Mini and sets the global standard for safe and effective wheel cleaning. This brush is specifically designed to reach deep into wheel barrels and remove stubborn brake dust and dirt without scratching. Thanks to the long, flexible stem, the brush effortlessly reaches behind spokes and between brake calipers, areas unreachable with a wash mitt.
The special Memory-Nylex bristles are gentle on all wheel finishes, from painted to chrome-plated aluminum. These bristles are resistant to powerful wheel cleaners and always return to their original shape when exposed to heat. The stem and tip are fully coated with rubber, ensuring no metal comes into contact with the vehicle. Its size also makes this brush excellent for cleaning engine bays, wheel wells, and exhaust tips.
Product number: EZ-BRUSH-L
  • Total length: 45 cm
  • Brush length: 23 cm
  • Length of the nylon hair: 5 cm
  1. Mix a wheel cleaner or car shampoo with water in a bucket.
  2. Immerse the brush in the soapy water to ensure proper lubrication.
  3. Gently move the brush between spokes and into wheel barrels.
  4. Rinse the brush frequently in the bucket to release trapped dirt.
  5. Thoroughly rinse both the surface and the brush with clean water after cleaning.
  6. Hang the brush to dry; the bristles will regain their original shape.
Tips
  • Have the bristles become flattened over time? Submerge the brush in warm water, and the bristles will recover their original shape.
  • Avoid pulling the brush out of tight crevices too quickly to prevent dirty water from splattering onto clothing or face.
Excellent wheel brush: soft yet effective, reaches deep between spokes and behind the rim, durable and easy to clean. Ideal for detailers and tight spaces, works well with wheel cleaners; worth the price despite some splatter and occasional handle wear.
2 - 3 of 102 reviews
Goed voor krappe ruimte
Fijne wielborstel, kunt in vrijwel alle hoekjes komen.
Leon - 01/05/2026
Fijne velgenborstel
Eerst wat huiverig voordat ik deze bestelde. Ik had diverse malen een velgenborstel die snel afbrak of harde haren als een bezem had. Goedkoop blijkt dan toch duurkoop.. Deze heeft dat niet en de steel voelt goed stevig aan. Door de dunne kern (die wel goed stevig is) ook goed tussen de velg en de remklauwen te komen zodat ook de klauwen goed te reinigen zijn. De haren voelen zachter aan dan je zou verwachten, al is het natuurlijk geen microvezel
Marcel - 22/04/2026
Prima borstel
Pas 1 keer gebruikt maar voelt prima en solide aan. Het is niet om er erg veel druk mee te zetten want dan buigt hij. Dus laat het schoonmaakmiddel (Bijvoorbeeld Koch Chemie Greenstar) zijn werk doen en niet de borstel. Omdat hij van haar is en niet van microvezel spettert hij wel wat. De haardichtheid van de grote variant is niet zo hoog als ik verwacht had. Maar daardoor is hij in gebruik wel dunner om ergens tussendoor te passen. Haren blijven wel mooi overeind staan. Het is nog afwachten hoe lang de rubber tip erop blijft zitten.
Michel - 16/04/2026
