Detail Wheel Brush Large
Art. nr. EZ-BRUSH-L
EZ Detail EZ Detail Brush Large - The ultimate wheel brush
The EZ Detail Brush Large is the bigger brother of the Mini and sets the global standard for safe and effective wheel cleaning. This brush is specifically designed to reach deep into wheel barrels and remove stubborn brake dust and dirt without scratching. Thanks to the long, flexible stem, the brush effortlessly reaches behind spokes and between brake calipers, areas unreachable with a wash mitt.
The special Memory-Nylex bristles are gentle on all wheel finishes, from painted to chrome-plated aluminum. These bristles are resistant to powerful wheel cleaners and always return to their original shape when exposed to heat. The stem and tip are fully coated with rubber, ensuring no metal comes into contact with the vehicle. Its size also makes this brush excellent for cleaning engine bays, wheel wells, and exhaust tips.
Product number: EZ-BRUSH-L
  • Total length: 45 cm
  • Brush length: 23 cm
  • Length of the nylon hair: 5 cm
  1. Mix a wheel cleaner or car shampoo with water in a bucket.
  2. Immerse the brush in the soapy water to ensure proper lubrication.
  3. Gently move the brush between spokes and into wheel barrels.
  4. Rinse the brush frequently in the bucket to release trapped dirt.
  5. Thoroughly rinse both the surface and the brush with clean water after cleaning.
  6. Hang the brush to dry; the bristles will regain their original shape.
Tips
  • Have the bristles become flattened over time? Submerge the brush in warm water, and the bristles will recover their original shape.
  • Avoid pulling the brush out of tight crevices too quickly to prevent dirty water from splattering onto clothing or face.
Excellent wheel brush: soft yet effective, reaches deep between spokes and behind the rim, durable and easy to clean. Ideal for detailers and tight spaces, works well with wheel cleaners; worth the price despite some splatter and occasional handle wear.
4 - 3 of 102 reviews
Ondanks de spetters 5 sterren
Ja de borstel structuur doet spetteren bij het heen en weer raggen. Maar ondanks het forse vormvast past het prima ook tussen de kleinere openingen wat ik niet had verwacht. Ik vond dit vele malen beter dan een microvezel borstel gezien het ook beter om De hoekjes gaat. Voor mij een dikke 10 maar dat zal ook wel per type velg afhangen. Ik rij een Kia Ceed en past probleemloos in alle openingen
Sebastian - 08/02/2026
Goede kwaliteit
Gekocht voor de lastig bereikbare plekken. Past helaas - in mijn geval - nog altijd niet tussen remklauw en velg. Voor de rest een prima borstel met zachte haren en merkbare kwaliteit!
Ivo - 30/01/2026
Geweldig
Ze zijn goedkoper geworden dan een paar jaar terug. Dat is nou nog eens top. Zet niet teveel druk en dan heb je er lang plezier van.
Joël - 24/12/2025
