Q²M Bathe+ - 500ml
Art. nr. GYBAP05
The world's very first SiO2 shampoo
Gyeon Q²M Bathe+ is the first pH-neutral shampoo with SiO2 in the world. Even a quick wash leaves behind a layer that strongly repels moisture and dirt, allowing you to postpone your next wash for a while. Washing with Q²M Bathe+ is a pleasure in itself. The shampoo is low-foaming, easy to use, and has that signature fragrance that fans of the entire Gyeon range have come to love.
The car stays clean much longer
When developing Q²M Bathe+, there was only one goal: to reduce a wash process that normally consists of multiple steps into a single, simple step. With ingredients that provide excellent water-repellent properties and a smooth washing experience. At the same time, it offers as many self-cleaning properties as possible, so the car needs less frequent washing than usual. A great advantage, especially in bad weather conditions.
Product number: GYBAP05
  • Licht biologisch afbreekbaar
H315: Causes skin irritation.
Corrosion: Corrosive
  • Slechts 15-20 ml Bathe+, opgelost in ongeveer 12 liter water, is genoeg om je auto te wassen en te voorzien van een gladde, zelfreinigende en waterafstotende laag, als de auto reeds beschermd is met een coating.
  • Voor gebruik zonder reeds aangebrachte coating, het product direct op de washmitt of spons aanbrengen tijdens het normale wassen.
  • Niet laten opdrogen, tijdig afspoelen, zeker bij warm weer. Niet in de zon gebruiken.
Gyeon Q2M Bathe+ is a premium after-wash shampoo that reliably boosts gloss, beading and sheeting; easy to use in a foam lance or on a mitt, gives coating-like hydrophobic protection and saves time—widely praised for visible, long-lasting results.
26 - 3 of 78 reviews
Monello non Ferro eerst gebruikt om alle vliegroest en dergelijke te verwijderen, werkte super goed. Daarna eerst goed afgespoten, gefoamd, met 2 emmer methode gewassen en dat in 4x ivm zeepvlekken (voorkant, linkerkant, achterkant en rechterkant + dak). Het is belangrijk om echt genoeg shampoo op je mitt te hebben zodat het goed zijn werk kan doen . Het resultaat was echt verbluffend!!! Bathe+ is shampoo, sealant, wax en detailer in 1 lijkt wel. De glans vind ik persoonlijk mooier dan een ultimate quick wax en/of detailer en het is ook vele malen waterafstotender. Beading ook veel mooier naar mijn gevoel. En dat alles met alleen maar wassen, in 1 enkele stap dus! Wat wel opvalt is dat zeepvlekken sneller ontstaan en ook niet meer zijn weg te krijgen zonder te polijsten. Daarom heb ik de auto in 4 delen gedaan. De shampoo foamt ook niet als een snow foam maar is wel prima goed te doen. Zeker aan te bevelen!
Xander Van Beek - 07/09/2014
Geweldig
Zojuist het product toegepast op een metallic zwarte auto..... GE-WEL-DIG! Bij het aanbrengen van het product (emmer water en mitt) lijkt er niks te gebeuren. Echter bij het afspoelen merk je dat er een zeer sterke afstotende laag aanwezig is. Daarbij glanst de auto alsof deze net is voorzien van een wax. Een puntje van kritiek is dat de werking aanzienlijk minder is als het product als shampoo wordt gebruikt. Je moet (zoals hierboven vermeld) product op je washmitt doen en vervolgens de gewassen delen nabehandelen. Hierdoor gebruik je (te) veel product. Al met al een blijvertje indien 4 weken+ standtijd wordt gehaald. Aanrader!
Robert den Hollander - 26/08/2014
Aanbevolen
Wow, wat een geweldige shampoo. Had niet verwacht dat zo'n dergelijke waterafstotende werking erin zou zitten.
Dave Hendriks - 25/08/2014
Koch-Chemie
Ceramic Effect Shampoo - 1000ml
  • Cleans and protects
  • Deep, long-lasting shine
  • Strong water-repellent effect
  • Fresh berry-almond scent
  • € 30.33
    Gtechniq
    W3 Ceramic GWash - 500ml
    • Ultagladde, geconcentreerde autoshampoo
    • Biedt tot 3 maanden waterafstotendheid
    • Laagschuimende formule
    € 29.49
    Nearly sold out
    Offer
    Sonax
    Xtreme Ceramic Active Shampoo - 500ml
    • Vuil- en waterafstotende eigenschappen
    • Voor onderhoud van keramische coatings
    • Geeft de lak direct een extra glans
    Retail price: € 17.99 € 14.99
    Offer
    Turtle Wax
    Hybrid Solutions Ceramic Wash & Wax - 1420ml
    • Shampoo met waterafstotende eigenschappen
    • Boost de werking van Hybrid Solutions
    • Voorzien van een heerlijke tropische geur
    Retail price: € 23.99 € 16.99
