Rapid Rinseless Wash - 1000ml
- Quick and waterhose free washing
- Gloss-enhancing formula
- Leaves a protective layer
- Highly versatile in use
Koch-Chemie Rapid Rinseless Wash - Washing without water has never been easier.
The Koch-Chemie Rapid Rinseless Wash, also known as Rrr, is the ideal solution for a quick and thorough wash without the need for a garden hose or high-pressure cleaner. This versatile product is specially developed to clean the vehicle in a safe and efficient manner, encapsulating dirt for safe removal without causing scratches. In addition to its cleaning action, it leaves behind a water-repellent and gloss-enhancing finish.
The Rapid Rinseless Wash is not only suitable for a rinseless wash but can also be used as a quick detailer, a drying aid after a traditional wash, or even as a clay lubricant. The formula is gentle on all exterior surfaces, including paint, glass, plastic, and wheels.
| Product number: | 475001 |
Dilute the Rapid Rinseless Wash according to the recommended ratio (approx. 30 ml to 10 liters of water) in a bucket.
Soak several microfiber towels in the solution.
Take a towel and wash the vehicle panel by panel, from top to bottom.
Use a clean, dry microfiber towel to immediately wipe and buff the treated panel to a high shine.
Replace the wash towel with a clean, wet one as soon as it becomes saturated with dirt.
Tip: For an extra smooth and water-repellent effect, use the Rapid Rinseless Wash as a drying aid. Spray a small amount onto a wet panel after washing and dry the surface with a drying towel.
2 - 3 of 4 reviews
Top product
Multifunctioneel en zeer voordelig in gebruik. Fijne rinseless wash in de emmer met goede spons, maar gebruik het ook als drooghulp en je kunt een spuitfles ermee vullen als kant en klare waterless wash voor noodgevallen (bijv. vogelpoep) of als prima klei smeermiddel. Lekker ruim gebruiken want een liter verdund product kost nog geen dubbeltje! (1:250 = 4ml voor 1l oplossing).
