Exterior
Claying never felt this good
Effective Decontamination
Monello Dolce Verde Clay is the perfect choice for anyone looking for effective, safe, and reliable surface decontamination. This soft clay easily removes stubborn contaminants such as tar, tree sap, industrial fallout, and other embedded grime that regular washing leaves behind. Thanks to its fine composition, the risk of marring is minimal, making it safe to use on all painted surfaces. The result? A silky smooth surface, fully prepped for polishing, waxing, or coating.
Like Play-Doh, but for car lovers
Flexible and Formable
Dolce Verde Clay is extremely easy to knead and mold, even at lower temperatures. You can quickly shape it into any form needed for optimal contact with the surface you're working on. This makes it ideal for both large panels and tighter areas like trim or door jambs. Folding the clay regularly helps trap dirt safely inside, so you’re always working with a clean piece and minimizing the risk of scratches.
Fits like a glove (but softer)
Comfort in Your Hands
Weighing 250 grams, this clay bar offers a solid, comfortable feel in your hand. It strikes the right balance between firmness and flexibility, making it easy to apply consistent pressure without straining your fingers. Whether you're wearing gloves or working barehanded, the clay adapts to your grip and gives you full control throughout the detailing process. It’s a small detail that makes a big difference during longer sessions.
The Dolce Verde is a fine cleaning clay to detail your car paint. When a 'normal' washing is not enough, the Dolce Verde polishing clay cleans your vehicle with great precision. The Dolce Verde is safe to use on various surfaces such as car paint, hard plastic, glass and mirrors. This soft clay is easy to model, sits well to your hand and can be used in a temperature range of 5 to 35 degrees. The Dolce Verde comes in a sturdy, plastic box.
| Product number | MON-DV1pc |
| Cleaning power | Normal |
| Hardness | Medium |
| Product form | Clay |
| Weight | 200 - 499 gram |
- Wash and dry the car: Always start with a thorough wash to remove loose dirt. Dry the car completely before claying.
- Knead the clay: Take about 1/3 of the clay bar and knead it into a flat disc, roughly palm-sized.
- Apply clay lubricant: Spray a generous amount of clay lube or quick detailer onto the area you're treating. This prevents scratching.
- Gently glide: Move the clay over the lubricated surface using light pressure. Use straight or overlapping passes. You'll feel resistance where contamination is present.
- Fold regularly: After each panel or two, fold the clay to reveal a clean surface. Discard the clay when it becomes too dirty.
- Wipe down: Use a clean microfiber towel to remove any residue. Repeat the process as needed for stubborn spots.
- Post-treatment: After claying, the surface is fully decontaminated and ready for polishing, waxing, or coating.
Note: Never use clay that has been dropped on the ground — it may contain particles that can scratch your paint. Store unused clay in a sealed container or ziplock bag to prevent drying out.
Goed product
Ik zou dit product nog een keer kopen.
Pettige doos en speciaal papiertje dat het niet plakt.
* Hoevaak kan je het gebruiken?
Je kan het meerdere keren gebruiken (5x), even stuk afsnijden.
* Hoe kan je het beste gebruiken?
In warm water laten zacht worden, dan wordt het kneedbaar.
Heel tevreden van de combinatie van producten
Ik ben blij dat ik het heb aangeschaft , niet moeilijk in gebruik na het bekijken van de gebruiksvideo. Ik sta er van versteld hoeveel vuil erachter blijft op de klei vooral op de deurpanelen aan de onderzijde. Hiervoor voelde dit grof aan maar het kleien zo glad als een aal. Op de andere delen van de auto was het lichtjes dat er vuil achterbleef op de klei. Dus een diķke duim hiervoor!
Simpel en top klei
Kwalitatief, voordelig en simpel te gebruiken klei waar iedereen aan de slag mee kan om echt goede resultaten te krijgen met het kleien (monnikenwerk).
Echte aanrader om o.a. vastzittende vervuiling in bijv. lakwerk weg te halen. Resultaat is een ontzettend glad en gereinigd oppervlak, waar je vervolgens mee verder kan voor het opvullen en afdichten om je perfecte resultaat voor een langere tijd te behouden.
