Dolce Verde klei - 250 gram
Art. nr. MON-DV1pc
4.6 (49)
  • Soft and ready to detail
    Good clay
Claying never felt this good
Effective Decontamination
Monello Dolce Verde Clay is the perfect choice for anyone looking for effective, safe, and reliable surface decontamination. This soft clay easily removes stubborn contaminants such as tar, tree sap, industrial fallout, and other embedded grime that regular washing leaves behind. Thanks to its fine composition, the risk of marring is minimal, making it safe to use on all painted surfaces. The result? A silky smooth surface, fully prepped for polishing, waxing, or coating.
Like Play-Doh, but for car lovers
Flexible and Formable
Dolce Verde Clay is extremely easy to knead and mold, even at lower temperatures. You can quickly shape it into any form needed for optimal contact with the surface you're working on. This makes it ideal for both large panels and tighter areas like trim or door jambs. Folding the clay regularly helps trap dirt safely inside, so you’re always working with a clean piece and minimizing the risk of scratches.
Fits like a glove (but softer)
Comfort in Your Hands
Weighing 250 grams, this clay bar offers a solid, comfortable feel in your hand. It strikes the right balance between firmness and flexibility, making it easy to apply consistent pressure without straining your fingers. Whether you're wearing gloves or working barehanded, the clay adapts to your grip and gives you full control throughout the detailing process. It’s a small detail that makes a big difference during longer sessions.
The Dolce Verde is a fine cleaning clay to detail your car paint. When a 'normal' washing is not enough, the Dolce Verde polishing clay cleans your vehicle with great precision. The Dolce Verde is safe to use on various surfaces such as car paint, hard plastic, glass and mirrors. This soft clay is easy to model, sits well to your hand and can be used in a temperature range of 5 to 35 degrees. The Dolce Verde comes in a sturdy, plastic box.
Product number MON-DV1pc
Cleaning power Normal
Hardness Medium
Product form Clay
Weight 200 - 499 gram
  1. Wash and dry the car: Always start with a thorough wash to remove loose dirt. Dry the car completely before claying.
  2. Knead the clay: Take about 1/3 of the clay bar and knead it into a flat disc, roughly palm-sized.
  3. Apply clay lubricant: Spray a generous amount of clay lube or quick detailer onto the area you're treating. This prevents scratching.
  4. Gently glide: Move the clay over the lubricated surface using light pressure. Use straight or overlapping passes. You'll feel resistance where contamination is present.
  5. Fold regularly: After each panel or two, fold the clay to reveal a clean surface. Discard the clay when it becomes too dirty.
  6. Wipe down: Use a clean microfiber towel to remove any residue. Repeat the process as needed for stubborn spots.
  7. Post-treatment: After claying, the surface is fully decontaminated and ready for polishing, waxing, or coating.
Note: Never use clay that has been dropped on the ground — it may contain particles that can scratch your paint. Store unused clay in a sealed container or ziplock bag to prevent drying out.
De Dolce Verde is een zachte klei, met een lichte neiging naar medium. Hij is dus zacht genoeg om veilig te gebruiken op gevoelige lakken, maar krachtig genoeg om vervuiling los te trekken. Er zijn nog zachtere kleien, maar deze biedt een fijne balans tussen veiligheid en effectiviteit.
Na gebruik even afspoelen, drogen en terugstoppen in het bijgeleverde kunststof doosje. Zo blijft de klei schoon, zacht en bruikbaar voor de volgende keer.
Met 250 gram klei kun je tot wel 20 auto's behandelen – afhankelijk van hoe vuil de lak is en hoe zuinig je werkt.
Je kunt deze klei veilig gebruiken op autolak, glas, spiegels en hard plastic. Ideaal als je grondig wilt reinigen vóór je gaat polijsten of waxen.
Heel goed
Prima klein die ook nog eens in een mooi doosje komt. Met een klein stukje kom je al een heel eind.
Mandy - 15 April 2026
Fijn product
Klei goed warm maken in de hand en je kan non stop aan de gang! Makkelijk te vouwen en weer door! Ik combineer de klei met de Poorboys detailspray.
Detailing By Birdsong - 20 March 2026
Prima klei
Prima klei. Doet wat het moet doen. Lijkt misschien hard in het begin, maar vormt zich prima onder het kleien. De autolak wordt er weer helemaal glad van. De klei zit in een praktische doos, erg handig.
Ernst - 28 June 2025
Dodo Juice
Supernatural Medium Grade Clay - 2x50=100g
  • Medium grade klei
  • Sneller en effectiever
  • Reinigt beter
  • Twee losse 50 gram stukken
€ 16.99
Bilt-Hamber
Auto-Clay Regular - 200g
  • Haalt alle vastzittende vervuiling veilig en effectief weg
  • Zijdezachte finish
  • Te gebruiken met detailerspray of alleen met water
  • Ook in 'Soft'-versie verkrijgbaar
€ 22.99
Offer
Meguiars
Smooth Surface Individual Clay Bar - 80 gram
  • Losse kleibar voor bestaande kits
  • Verwijdert veilig oppervlaktevervuiling
  • Niet-schurend & eenvoudig in gebruik
  • Te gebruiken met bijv. Quik Detailer
Retail price: € 23.16 € 18.53
Nearly sold out
New
Offer
Dolce Verde Klei Set
  • Economical set for perfect detailing results
  • Includes Perfetto and Peluche Verde
Retail price: € 40.50 € 35,-
Purple Clay Bar - 100 gram
  • Zachte klei
  • Veilig voor lak & glaswerk
  • Te combineren met Nanolex Clay Lube
€ 13.99
Nearly sold out
Blogs about this product
