Detailers review
- Groter formaat dan standaard, merkbaar prettiger in gebruik
- Zachte vezels met perfecte balans tussen opname en soepelheid
- Satijnen rand voorkomt krasjes en rafelen
- Door de felle groene kleur kan de doek iets afgeven in de was
- Geen gesloten vezelstructuur, dus meer weerstand bij het uitwrijven
Monello Peluche Verde - The versatile green all-rounder
The Monello Peluche Verde is an absolute classic within the detailing world and is known for its excellent price-quality ratio. This green microfiber towel has a weight of 350 grams per square meter, providing a perfect balance between softness and effectiveness. The towel is neither too thick nor too thin, allowing for plenty of feedback while working on the paintwork. The long fibers safely absorb polish residue, wax, glaze, and sealants into the towel, rather than dragging them across the paint.
The size of 45x45cm is the industry standard for manageable work. The Peluche Verde is extremely versatile: from removing polish to applying a spray detailer or cleaning the interior. The edges are finished with a soft border to minimize the risk of marring (light sweep scratches). An indispensable towel in every detailing kit.
| Product number: | MPV0101 |
| Gram per vierkante meter: | 350 |
- Size: 45x 45 cm
- 350 gsm
Fold the towel twice before use to create a manageable square with eight clean sides. Rub with light pressure over the surface to remove the residue of wax, polish, or spray. Once a side is saturated, flip the towel or refold it to a clean side for a streak-free result.
Tips Always wash new microfiber towels before first use to remove any loose lint from production. Do not use fabric softener, as this clogs the fibers and reduces absorbency.
Om de doek zacht en effectief te houden, volg je deze wasregels:
- Was de doeken in de wasmachine op maximaal 40°C (of 60°C bij extreme vervuiling).
- Gebruik een vloeibaar wasmiddel (bij voorkeur een speciale microvezelreiniger).
- Gebruik absoluut geen wasverzachter; dit legt een laagje over de vezels waardoor ze geen product of water meer opnemen.
- Was ze niet samen met katoenen handdoeken om te voorkomen dat de microvezels vol gaan zitten met pluizen.
De Peluche Verde is handig dubbelzijdig opgebouwd:
- De langharige, pluche kant: Ideaal voor het veilig opnemen van stof, quick detailers of het eerste residu van wax, omdat vuil diep in de vezels wordt ingekapseld.
- De kortharige, compacte kant: Perfect voor het fijnere opwrijfwerk en het streeploos afnemen van polijstpasta, omdat deze kant meer "grip" heeft op het oppervlak.
Hoewel de Peluche Verde door zijn zachtheid prima water opneemt, is hij met zijn formaat van 45x45cm te compact om als primaire droogdoek te dienen. Voor het drogen van de complete auto raden we een grotere, gespecialiseerde droogdoek aan. De Peluche Verde is wel perfect voor het drogen van deursponningen of de binnenkant van de achterklep.
Dankzij de perfecte vezellengte is de Peluche Verde een echte allrounder. De doek is ideaal voor:
- Het residu van polijstmiddelen (Monello Mezzo/Finale) streeploos afnemen.
- Het uitpoetsen (uitbuffen) van vloeibare of vaste waxen en sealants.
- Het verwerken van quick detailers of spray-waxen.
- Veilig stoffen en reinigen van het interieur (zoals het dashboard).
De Peluche Verde is specifiek ontwikkeld voor krasgevoelige autolakken. De doek heeft een gewicht van 350 g/m² (GSM), wat hem heerlijk zacht en dik maakt. Het belangrijkste voordeel is echter dat deze doek randloos (edgeless) is. Omdat er geen harde stiksels of labels aan de randen zitten, is de kans op het veroorzaken van krassen of swirls tijdens het wrijven nagenoeg nul.
22 - 3 of 65 reviews
Eerste klas
Heerlijk zachte doek. Super handig voor zowel het gebruik met een quick detail spray als het uitpoetsen van een wax! Gewoon een goed product!!!
Uitstekend
Als eerste wil ik Carclean bedanken voor dit leuke presentje die bij mijn bestelling zat! Ik heb hem vandaag zonder voor te wassen gebruikt om de binnen ruiten na te wrijven, na het inwrijven van Meguiars glass cleaner concentrate met een glasdoek. De voorruit was ongewassen voordat ik de glascleaner gebruikte en was zeker een jaar al niet meer gereinigd. (in de auto word niet gerookt) Na het inwrijven met de glasdoek was de ruit nog niet helemaal proper, maar na een ronde peluche verde met de korte vezel-kant, gevolgd door een ronde met de lange vezel-kant was de ruit helemaal helder. Je moet wel behoorlijk wat kracht zetten voor een goede werking. Een echte topper. Hopelijk blijft deze doek na een aantal keren wassen even goed werken. Nog een pluspunt is dat je totaal geen last van pluisvorming hebt.
Small but mighty
Compact and Handy
The Monello Peluche Verde microfiber towel, with its convenient size of 45x45 cm, is the perfect choice for car enthusiasts. Not too big, not too small, but just right for effortless cleaning. Its size makes it easy to handle, even in tricky areas like door frames and mirrors. At the same time, it offers enough surface area to work effectively without the need for constant folding or repositioning. Whether you’re a beginner or an experienced detailer, this towel seamlessly fits into your routine.
Wax on, polish off
Ideal for Wax and Polish
Thanks to its ultra-soft fibers, the Monello Peluche Verde is the perfect companion for removing waxes and polishes. The towel glides smoothly over surfaces, effortlessly picking up product residues without leaving scratches behind. The result? A brilliant, streak-free finish you can be proud of. Its high absorption capacity makes it ideal for removing excess product, leaving your paintwork looking sleek and shiny. You’ll be amazed at how quickly and efficiently it gets the job done.
This towel does it all
Great for Interior Use Too
This towel isn’t just great for the exterior of your car; it’s also a standout performer for interior cleaning. Use the Monello Peluche Verde to remove dust, fingerprints, and dirt from your dashboard, door panels, and other surfaces. Its soft texture ensures no damage while leaving your interior looking fresh and clean. Plus, it’s compact enough to store in your glove box or detailing kit, so you’re always ready for a quick touch-up. Truly a versatile tool!
