Peluche Verde Trio - 45x45cm
Art. nr. MPV0103
4.8 (82)
  • Versatile
    Soft green towel
Small but mighty
Compact and Handy
The Monello Peluche Verde microfiber towel, with its convenient size of 45x45 cm, is the perfect choice for car enthusiasts. Not too big, not too small, but just right for effortless cleaning. Its size makes it easy to handle, even in tricky areas like door frames and mirrors. At the same time, it offers enough surface area to work effectively without constant folding or repositioning. Additionally, the towel is available in an economical set of three, ensuring you always have enough on hand. Whether you’re a beginner or an experienced detailer, this towel seamlessly fits into your routine.
Autowasserette, Volwassene, Mannelijk, Man, Persoon
Binnenshuis, Interieurontwerp, Schoonmaak, Persoon, Hand
Wax on, polish off
Ideal for Wax and Polish
Thanks to its ultra-soft fibers, the Monello Peluche Verde is the perfect companion for removing waxes and polishes. The towel glides smoothly over surfaces, effortlessly picking up product residues without leaving scratches behind. The result? A brilliant, streak-free finish you can be proud of. Its high absorption capacity makes it ideal for removing excess product, leaving your paintwork looking sleek and shiny. You’ll be amazed at how quickly and efficiently it gets the job done.
This towel does it all
Great for Interior Use Too
This towel isn’t just great for the exterior of your car; it’s also a standout performer for interior cleaning. Use the Monello Peluche Verde to remove dust, fingerprints, and dirt from your dashboard, door panels, and other surfaces. Its soft texture ensures no damage while leaving your interior looking fresh and clean. Plus, it’s compact enough to store in your glove box or detailing kit, so you’re always ready for a quick touch-up. Truly a versatile tool!
Lichaamsdeel, Hand, Persoon
Monello Peluche Verde Trio - Versatile softness for paintwork
This set consists of three high-quality microfiber towels known for their versatility. With a density of 350 GSM (grams per square meter), the Peluche Verde offers an excellent balance between softness and cleaning power. This makes the towels extremely suitable for wiping off polishing compounds, wax residues, and detailers, but they can also be safely used for interior cleaning.
The fiber structure ensures that dirt and residue are effectively absorbed and trapped, rather than being pushed around. The edges feature a soft, satin finish to minimize the risk of scratches. The 45x45cm size is slightly larger than standard, providing a comfortable working surface that handles well. While the towel is very soft, it may be less suitable for extremely sensitive paints compared to the heavier variants in the Monello line. Nevertheless, this is the ideal 'workhorse' towel for almost any detailing job.
Product number MPV0103
Color Green
Dikte van de microvezeldoek Normaal 300 - 399 gram/m²
Lengte vezel microvezeldoek Kort en lang
Size Large
Suitable for application Afnemen detailers, Afnemen glaze, wax en sealant, Afnemen polijstmiddel, Afnemen Spraywaxen
Type of fiber Fleece
Fold the towel twice before use to create a manageable square with eight clean sides. Rub with light pressure over the surface to remove the residue of wax, polish, or spray. Once a side is saturated, flip the towel or refold it to a clean side for a streak-free result.
Tips Always wash new microfiber towels before first use to remove any loose lint from production. Do not use fabric softener, as this clogs the fibers and reduces absorbency.
Om de doek zacht en effectief te houden, volg je deze wasregels:
  • Was de doeken in de wasmachine op maximaal 40°C (of 60°C bij extreme vervuiling).
  • Gebruik een vloeibaar wasmiddel (bij voorkeur een speciale microvezelreiniger).
  • Gebruik absoluut geen wasverzachter; dit legt een laagje over de vezels waardoor ze geen product of water meer opnemen.
  •  Was ze niet samen met katoenen handdoeken om te voorkomen dat de microvezels vol gaan zitten met pluizen.
De Peluche Verde is handig dubbelzijdig opgebouwd:
  • De langharige, pluche kant: Ideaal voor het veilig opnemen van stof, quick detailers of het eerste residu van wax, omdat vuil diep in de vezels wordt ingekapseld.
  • De kortharige, compacte kant: Perfect voor het fijnere opwrijfwerk en het streeploos afnemen van polijstpasta, omdat deze kant meer "grip" heeft op het oppervlak.
Hoewel de Peluche Verde door zijn zachtheid prima water opneemt, is hij met zijn formaat van 45x45cm te compact om als primaire droogdoek te dienen. Voor het drogen van de complete auto raden we een grotere, gespecialiseerde droogdoek aan. De Peluche Verde is wel perfect voor het drogen van deursponningen of de binnenkant van de achterklep.
Dankzij de perfecte vezellengte is de Peluche Verde een echte allrounder. De doek is ideaal voor:
  • Het residu van polijstmiddelen (Monello Mezzo/Finale) streeploos afnemen.
  • Het uitpoetsen (uitbuffen) van vloeibare of vaste waxen en sealants.
  • Het verwerken van quick detailers of spray-waxen.
  •  Veilig stoffen en reinigen van het interieur (zoals het dashboard).
De Peluche Verde is specifiek ontwikkeld voor krasgevoelige autolakken. De doek heeft een gewicht van 350 g/m² (GSM), wat hem heerlijk zacht en dik maakt. Het belangrijkste voordeel is echter dat deze doek randloos (edgeless) is. Omdat er geen harde stiksels of labels aan de randen zitten, is de kans op het veroorzaken van krassen of swirls tijdens het wrijven nagenoeg nul.
Goede kwaliteit
Goede kwaliteit doeken tegen een mooie prijs. Blijven na diverse keren wassen nog steeds netjes en doen hun werk.
Nathan - 1 December 2021
Fijne doeken
Kwaliteit doeken hoor!
Totaal niets mis mee.
Tip:
Voor gebruik eerst even wassen in een emmer en goed uitspoelen.(anders wordt je wasgoed groen)
Henk-Jan - 30 September 2021
Zeer fijne doeken!
Deze doeken zijn mij zeer goed bevallen. Ideaal voor het afnemen van polijstmiddel of wax. Ik heb de doeken na gebruik direct in een emmer met een flinke scheut schoonmaakazijn, wat apc en water gedaan. Nadat ik alles in de wasmachine had gedaan zag ik dat het water in de emmer groen gekleurd was. Vervolgens hebben de doeken in de wasmachine niet meer afgegeven op andere doeken.
Olav - 29 June 2021
Q²M PolishWipe EVO - 40x40cm
  • De ideale doek om lak te ontvetten voordat er een coating wordt aangebracht
  • Laser gesneden extra zachte vezels
  • Formaat 40x40cm
€ 7.99
Favorite
Peluche Verde - 45x45cm
  • Versatile soft microfiber towel
  • Weight of 450 GSM
  • Safely buffs off wax
  • Handy 45x45cm size
€ 5,-
Offer
Due Lati Polishing Towel - 3-pack
Retail price: € 19,- € 15,-
Blogs about this product
