Protecting
Small but mighty
Compact and Handy
The Monello Peluche Verde microfiber towel, with its convenient size of 45x45 cm, is the perfect choice for car enthusiasts. Not too big, not too small, but just right for effortless cleaning. Its size makes it easy to handle, even in tricky areas like door frames and mirrors. At the same time, it offers enough surface area to work effectively without constant folding or repositioning. Additionally, the towel is available in an economical set of three, ensuring you always have enough on hand. Whether you’re a beginner or an experienced detailer, this towel seamlessly fits into your routine.
Wax on, polish off
Ideal for Wax and Polish
Thanks to its ultra-soft fibers, the Monello Peluche Verde is the perfect companion for removing waxes and polishes. The towel glides smoothly over surfaces, effortlessly picking up product residues without leaving scratches behind. The result? A brilliant, streak-free finish you can be proud of. Its high absorption capacity makes it ideal for removing excess product, leaving your paintwork looking sleek and shiny. You’ll be amazed at how quickly and efficiently it gets the job done.
This towel does it all
Great for Interior Use Too
This towel isn’t just great for the exterior of your car; it’s also a standout performer for interior cleaning. Use the Monello Peluche Verde to remove dust, fingerprints, and dirt from your dashboard, door panels, and other surfaces. Its soft texture ensures no damage while leaving your interior looking fresh and clean. Plus, it’s compact enough to store in your glove box or detailing kit, so you’re always ready for a quick touch-up. Truly a versatile tool!
Monello Peluche Verde Trio - Versatile softness for paintwork
This set consists of three high-quality microfiber towels known for their versatility. With a density of 350 GSM (grams per square meter), the Peluche Verde offers an excellent balance between softness and cleaning power. This makes the towels extremely suitable for wiping off polishing compounds, wax residues, and detailers, but they can also be safely used for interior cleaning.
The fiber structure ensures that dirt and residue are effectively absorbed and trapped, rather than being pushed around. The edges feature a soft, satin finish to minimize the risk of scratches. The 45x45cm size is slightly larger than standard, providing a comfortable working surface that handles well. While the towel is very soft, it may be less suitable for extremely sensitive paints compared to the heavier variants in the Monello line. Nevertheless, this is the ideal 'workhorse' towel for almost any detailing job.
| Product number | MPV0103 |
| Color | Green |
| Dikte van de microvezeldoek | Normaal 300 - 399 gram/m² |
| Lengte vezel microvezeldoek | Kort en lang |
| Size | Large |
| Suitable for application | Afnemen detailers, Afnemen glaze, wax en sealant, Afnemen polijstmiddel, Afnemen Spraywaxen |
| Type of fiber | Fleece |
Fold the towel twice before use to create a manageable square with eight clean sides. Rub with light pressure over the surface to remove the residue of wax, polish, or spray. Once a side is saturated, flip the towel or refold it to a clean side for a streak-free result.
Tips Always wash new microfiber towels before first use to remove any loose lint from production. Do not use fabric softener, as this clogs the fibers and reduces absorbency.
Aanrader !!!!
Door zijn 2 verschillende kanten veelzijdig in gebruik.
Samen met de Q2Prep neem je makkelijk met de lange vezels na het polijsten de resten weg en is hij klaar voor de volgende stap of om de wax aan te brengen waar hij ook zijn veelzijdigheid weer bewijst. Waxresten wegnemen ( inmasseren ) met de lange vezels en oppoetsen met de kortharige kant. Bling Bling.....zijn afmetingen en gewicht zijn ideaal!
Perfecte doeken voor zowel afdrogen als na het polijsten
Perfecte doeken voor zowel afdrogen als na het polijsten.
Makkelijk om polijstmiddel af te nemen.
Handig die 2 kanten
Erg handig dat het een 2 in 1 doek is. De lange vezel om het product goed in te werken en de korte vezel voor afnemen. Je voelt dat het een kwaliteits doek is, geen slap/dun doekje die na 1x gebruiken al op is. Onmisbaar in mijn autopoets tas.
