Raffino Fine Finishing Pad - 75mm
Art. nr. MRFIP3
5.0 (8)
  • Een echte alleskunner
    Onze blauwe krokodil
Vertrouwde kwaliteit
Gemaakt in de VS
Wel zo handig
Beide zijdes tegelijkertijd
Goed gemaakt
Stevige nylon borstelharen
Monello Raffino Fine Finishing Pad - For a mirror-smooth finish.
An ultra-soft polishing pad made of special foam, designed to elevate car paint to an unparalleled high gloss. This product is highly suitable for removing very light paint defects such as holograms and marring, and for optimizing the gloss. Additionally, the pad is ideal for the machine application of a wax or sealant.
The foam has a flared design, providing more stability on the paintwork and less distortion during polishing. The pad is 25 mm thick, features a center cooling hole, and comes in a resealable package for dust-free storage after use. Naturally, the pad must be thoroughly cleaned and stored completely dry.
Product number MRFIP3
Color Red
Geschikt voor Ø steunschijf 70 - 75 mm
Made from material Foam
Polishing power Mild
Suitable for Bumpers, Dorpels, Mirrors, Motor cycles, Raamstijlen, Wheel and door shuts
Suitable for application Glaze, wax of sealant, Polishing, Waxing
Suitable for type machine Excentric / Dual Action
Type polijstpad Foam
Attach the pad as precisely as possible in the center of the backing plate of the polishing machine. Apply a small amount of polish, glaze, or wax to the surface of the foam. Work the product evenly at a low to medium speed. Apply light to no pressure, depending on the product.
After polishing, remove the residue with a clean, high-quality microfiber towel.
Tips
  • Clean the pad regularly during use with warm water to prevent product and dust buildup.
  • Wash the pad immediately after use with warm water and a suitable pad cleaner or a little dish soap. Do not wash in the washing machine, do not soak in water.
Voor de ultieme glans combineer je deze rode pad met een fijne nabewerkingspasta, zoals de Monello Raffini Finale. Dit is de vaste finishing-combinatie na een grove of medium polijstronde, en is tevens dé perfecte set om zachte lakken in één stap naar showroomniveau te brengen.
Nee, voor het verwijderen van diepere krassen of hardnekkige swirls is deze pad veel te zacht. Gebruik daarvoor eerst een grove pad (paars, Raffino Forte) of medium pad (oranje, Raffino Medio). De rode pad is echt de "finishing touch" die de lak perfect afsluit qua glans
In de nieuwe Raffino-generatie heeft Monello de kleuren en foamstructuren vernieuwd. Waar voorheen de witte pad werd gebruikt voor de fijnste polijststap, is dat nu deze rode pad. Hij beschikt over een geoptimaliseerde celstructuur die polijstmiddel gelijkmatiger verdeelt en warmte beter afvoert, wat zorgt voor een streeploos en superieur finish-resultaat.
De rode Raffino Fine pad heeft vrijwel geen slijpkracht (cut) van zichzelf. Hij is puur ontwikkeld om de lak te verfijnen tot een extreme hoogglans. Je gebruikt hem als laatste polijststap om hologrammen, een lichte waas en micro-swirls te verwijderen, of om lakken die al in topstaat zijn die bekende "natte" look te geven.
Ideaal
Ideale pad voor wax aan te brengen of na polijsten. Zacht en toch stevig met koelgat. Mooi!
Charles - 5 November 2026
Onmisbare pad
Een onmisbare pad voor de perfectionist. Hij herstelt geen lakdefecten, maar blinkt uit in zijn pure taak: een show-waardige reflectie garanderen zonder micro-krasjes achter te laten.
Benny - 11 July 2026
De nieuwe standaard
Als onderdeel van het Carclean testpanel heb ik de nieuwe serie pads flink mogen uittesten. De pads zijn in kwaliteit nu van het kaliber Scholl, Gyeon, Rupes etc. Ze zijn onverwoestbaar door de nieuwe verlijming. Het is tevens makkelijk om mee te werken. Wat ook fijn is, in het vele kleuren tijdperk, dat je op de achterkant in een keer ziet met welke pad je te maken hebt. Deze finishing pad is het meest geschikt voor de perfectionist om het mooiste resultaat te behalen en tevens geschikt voor het aanbrengen van een beschermlaag (bijvoorbeeld Collinite 845)
Slome - 28 June 2026
Q²M Finish Eccentric - 145mm
  • Lichte finishing pad voor het verwijderen van lichte lakdefecten
  • Speciaal ontworpen voor excentrische (Dual Action-) machines
  • Verkrijgbaar in twee formaten: 80mm en 145mm
  • Hoogte: 20mm
€ 13.99
Offer
Rupes
D-A Fine Polishing Foam Pad - 130/150 mm
  • Fijne polijstpad voor afwerking en lichte tot medium lakcorrectie
  • Geschikt voor lichte en medium polijstmiddelen
  • Individueel verpakt in flow pack
  • Werkt het beste i.c.m. Rupes D-A Fine Polishing Compound
Retail price: € 20.33 € 12.99
Offer
Rupes
D-A Ultra-Fine Polishing Foam Pad - Diverse maten
  • Ultra fijne polijstpad voor de mooiste afwerking
  • Geschikt voor zelfs de meest gevoelige lakken
  • Werkt het beste i.c.m. Rupes UNO Pure
Retail price: € 13.13 € 9.99
Offer
Rupes
Yellow Rotary Fine Polishing Pad - 130/135mm
  • Fijne polijstpad voor roterende polijstmachines
  • Verwijdert lichte swirls en andere imperfecties
  • De open cel stuctuur beperkt de kans op verbranden
Retail price: € 13.99 € 11.99
Nearly sold out
Koch-Chemie
Fine Cut Foam Pad - 76mm
  • Medium polishing pad
  • Removes moderate defects
  • Stable and flexible
  • Long-lasting performance
  • € 10.27
    Blogs about this product
