Machinaal polijsten
Vertrouwde kwaliteit
Gemaakt in de VS
Wel zo handig
Beide zijdes tegelijkertijd
Goed gemaakt
Stevige nylon borstelharen
Monello Raffino Forte Cutting Pad - Restores paintwork with precision.
The Raffino Forte Cutting Pad is a polishing pad designed for dual-action polishers. This product is intended for removing deeper swirls and scratches, severe oxidation, and other significant paint defects. It can be used with medium and heavy polishing compounds. The firm foam breaks down the abrasive particles effectively and, especially for a coarse polishing pad, delivers an excellent finish, meaning very little follow-up work is required.
The foam has a slightly flared design, making the pad more stable on the paintwork and reducing deformation during polishing. The pad is 25 mm thick, features a cooling hole in the center, and comes in a resealable package so you can store it dust-free after use. Naturally, be sure to clean the pad thoroughly first and store it completely dry.
| Product number | MRFP3 |
| Color | Purple |
| Geschikt voor Ø steunschijf | 70 - 75 mm |
| Polishing power | Strong |
| Suitable for | Bumpers, Dorpels, Mirrors, Motor cycles, Raamstijlen, Wheel and door shuts |
| Suitable for application | Polishing, Scratch Repair |
| Suitable for type machine | Excentric / Dual Action |
| Type polijstpad | Foam |
Center the pad as accurately as possible on the backing plate of the polishing machine. Apply a small amount of polish or compound to the surface of the foam. Work the product in evenly at a low to medium to high speed. Apply moderate pressure, depending on the product.
After polishing, wipe away the residue with a clean, high-quality microfiber towel.
Tips
- Clean the pad regularly during use with warm water to prevent the buildup of product and dust.
- Wash the pad immediately after use with warm water and a suitable pad cleaner or a small amount of dish soap. Do not wash in the washing machine, and do not leave to soak in water.
Super
Superfijne krachtige en stevige pad die met gemak krassen verwijdert. Ook voorzien van koelgat in het midden om oververhitting te voorkomen.
De nieuwe standaard
Als onderdeel van het Carclean testpanel heb ik de nieuwe serie pads flink mogen uittesten. De pads zijn in kwaliteit nu van het kaliber Scholl, Gyeon, Rupes etc. Ze zijn onverwoestbaar door de nieuwe verlijming. Het is tevens makkelijk om mee te werken. Wat ook fijn is, in het vele kleuren tijdperk, dat je op de achterkant in een keer ziet met welke pad je te maken hebt. Deze cutting pad heeft voldoende 'bite'
Fijne pad
Zeker een fijne pad geworden, weer een stapje beter dan de oude monello pads. Net wat dikker, betere kwaliteit foam. Echt een aanrader.
