Machinaal polijsten
Vertrouwde kwaliteit
Gemaakt in de VS
Wel zo handig
Beide zijdes tegelijkertijd
Goed gemaakt
Stevige nylon borstelharen
Monello Raffino Forte Cutting Pad - Restores paintwork with precision.
The Raffino Forte Cutting Pad is a polishing pad designed for dual-action polishers. This product is intended for removing deeper swirls and scratches, severe oxidation, and other significant paint defects. It can be used with medium and heavy polishing compounds. The firm foam breaks down the abrasive particles effectively and, especially for a coarse polishing pad, delivers an excellent finish, meaning very little follow-up work is required.
The foam has a slightly flared design, making the pad more stable on the paintwork and reducing deformation during polishing. The pad is 25 mm thick, features a cooling hole in the center, and comes in a resealable package so you can store it dust-free after use. Naturally, be sure to clean the pad thoroughly first and store it completely dry.
| Product number | MRFP3 |
| Color | Purple |
| Geschikt voor Ø steunschijf | 70 - 75 mm |
| Polishing power | Strong |
| Suitable for | Bumpers, Dorpels, Mirrors, Motor cycles, Raamstijlen, Wheel and door shuts |
| Suitable for application | Polishing, Scratch Repair |
| Suitable for type machine | Excentric / Dual Action |
| Type polijstpad | Foam |
Center the pad as accurately as possible on the backing plate of the polishing machine. Apply a small amount of polish or compound to the surface of the foam. Work the product in evenly at a low to medium to high speed. Apply moderate pressure, depending on the product.
After polishing, wipe away the residue with a clean, high-quality microfiber towel.
Tips
- Clean the pad regularly during use with warm water to prevent the buildup of product and dust.
- Wash the pad immediately after use with warm water and a suitable pad cleaner or a small amount of dish soap. Do not wash in the washing machine, and do not leave to soak in water.
prima pad
dikke stevige pad die met klittenband op de steunplaat wordt geplaatst. Door de dikte kun je bij een auto met randen en rondingen beter poetsen dan met de oude wat dunnere pad.
Komt goed los na gebruik en is prima te reinigen.
Prima pad
Stevige polijstpad. Corrigeert goed icm zwaardere polijstmiddel. De pad is vrij hoog t.o.v. andere pads. Kan even wennen zijn. Maar heeft ook voordelen met bepaalde rondingen en randen van een auto. De velcro kleeft super goed aan de steunplaat vast. Dus met beleid verwijderen. Verder niks op aan te merken.
Lekker stevge pad
Deze cutting pad is echt stevig maar wel met een meer open structuur. Polijstmiddel kan er wat dieper intrekken tijdens gebruik en warm worden dus spoel deze op tijd uit om gumming te voorkomen.
De pad blijft zeer goed zitten op de klittenband van diverse machines, dit is gewoon een heel erg goede cutting pad.
Ook vind ik de kleur mooi, het toch vaak witte polijstmiddel is erg goed zichtbaar, handig met schoonmaken.
