Machinaal polijsten
Vertrouwde kwaliteit
Gemaakt in de VS
Wel zo handig
Beide zijdes tegelijkertijd
Goed gemaakt
Stevige nylon borstelharen
Monello Medio Polishing Pad - The step to perfect gloss
A flawless car paint without light scratches or holograms is the ultimate goal. This is a medium polishing pad specifically designed for eccentric polishing machines, also known as dual-action machines. The pad efficiently removes light paint defects such as swirls and holograms and is made of durable, premium foam.
The foam has a slight flare, making the pad more stable on the paintwork and reducing distortion during polishing. The pad is 25 mm thick, features a cooling hole in the center, and comes in a resealable package to allow for dust-free storage after polishing. Naturally, the pad must be thoroughly cleaned first and stored completely dry.
| Product number | MRMP3 |
| Color | Orange |
| Geschikt voor Ø steunschijf | 70 - 75 mm, 125 mm |
| Polishing power | Medium |
| Suitable for | Bumpers, Dorpels, Mirrors, Motor cycles, Raamstijlen, Wheel and door shuts |
| Suitable for application | Polishing |
| Suitable for type machine | Excentric / Dual Action |
| Type polijstpad | Foam |
Attach the pad as precisely as possible in the center of the backing plate of the polishing machine. Apply a small amount of polish to the surface of the foam. Work the product evenly at medium speed. Apply light to moderate pressure, depending on the product.
After polishing, remove the residue with a clean, high-quality microfiber towel.
Tips
- Clean the pad regularly during use with warm water to prevent product and dust buildup.
- Wash the pad immediately after use with warm water and a suitable pad cleaner or a little dish soap. Do not wash in the washing machine, do not soak in water.
Goede pad
Fijne medium pad. Echt stapje beter dan de oude pads, mooier afgewerkt en ook net wat dikker. Ook ideaal voor large throw machines.
goede pad
dikke medium pad die met klittenband op de steunplaat wordt geplaatst. Door de dikte kun je bij een auto met randen en rondingen beter poetsen dan met de oude wat dunnere pad.
Komt goed los na gebruik en is prima te reinigen.
Goede allrounder pad
Deze pad is geschikt voor medium polijstwerk. De pad is vrij stevig. En corrigeert ook goed icm een compound.
De pad kleeft goed vast aan de steunplaat. En is ook makkelijk schoon te maken na gebruik. Top
