Raffino Medio Polishing Pad -75mm
Art. nr. MRMP3
5.0 (8)
  • Een echte alleskunner
    Onze blauwe krokodil
Vertrouwde kwaliteit
Gemaakt in de VS
Wel zo handig
Beide zijdes tegelijkertijd
Goed gemaakt
Stevige nylon borstelharen
Monello Medio Polishing Pad - The step to perfect gloss
A flawless car paint without light scratches or holograms is the ultimate goal. This is a medium polishing pad specifically designed for eccentric polishing machines, also known as dual-action machines. The pad efficiently removes light paint defects such as swirls and holograms and is made of durable, premium foam.
The foam has a slight flare, making the pad more stable on the paintwork and reducing distortion during polishing. The pad is 25 mm thick, features a cooling hole in the center, and comes in a resealable package to allow for dust-free storage after polishing. Naturally, the pad must be thoroughly cleaned first and stored completely dry.
Product number MRMP3
Color Orange
Geschikt voor Ø steunschijf 70 - 75 mm, 125 mm
Polishing power Medium
Suitable for Bumpers, Dorpels, Mirrors, Motor cycles, Raamstijlen, Wheel and door shuts
Suitable for application Polishing
Suitable for type machine Excentric / Dual Action
Type polijstpad Foam
Attach the pad as precisely as possible in the center of the backing plate of the polishing machine. Apply a small amount of polish to the surface of the foam. Work the product evenly at medium speed. Apply light to moderate pressure, depending on the product.
After polishing, remove the residue with a clean, high-quality microfiber towel.
Tips
  • Clean the pad regularly during use with warm water to prevent product and dust buildup.
  • Wash the pad immediately after use with warm water and a suitable pad cleaner or a little dish soap. Do not wash in the washing machine, do not soak in water.
De Medio pad (oranje) is een medium polijstpad. Dit betekent dat hij een gemiddelde "cut" (slijpkracht) heeft. Hij is specifiek ontwikkeld om lichte tot gemiddelde lakdefecten aan te pakken, zoals fijne swirls, waskrassen en lichte oxidatie, terwijl hij tegelijkertijd de lak al naar een zeer hoog glansniveau tilt.
De Raffino Medio is de directe opvolger van de bekende oranje Raffini pad. De vernieuwde Raffino-serie beschikt over een verbeterde celstructuur in het foam. Hierdoor houdt de pad polijstpasta beter vast, sluit hij minder snel dicht met residu en voert hij warmte effectiever af, wat de levensduur aanzienlijk verlengt.
Voor de perfecte match combineer je deze pad met een medium polijstpasta, zoals de Monello Raffini Mezzo. Op veel laksoorten (met name de gemiddelde tot harde lakken) is deze combinatie dé gouden formule voor een zogenaamde '1-staps correctie': je verwijdert de meeste swirls en finisht direct met een prachtige glans.
goede pad, stevig genoeg.
Deze pad bevalt me goed, ik kan er een hoge glans mee bereiken, met een medium polijstmiddel is het aanpakken van swirls snel gedaan, ook laat deze pad zich fijn uitspoelen/schoonmaken.
De trapeze vorm (ook bekend van andere merken) geeft een mooi stabiel draaimoment van de pad met de machine.
Slijtage is nog niet te merken.
Michel - 25 June 2026
Medium pad voor de meeste toepassingen geschikt.
Medium pad met goede velcro die zich zonder geweld laat losmaken van de machine. Handig gat in het midden om te centreren. Bij gebruik van een pad-prep (of Spray&Wipe) en een goede reiniger is de pad na gebruik goed schoon te krijgen.
Mag niet ontbreken in de voorraad, laat zich effectief inzetten tegen lichte lakschade.
Hans - 24 June 2026
Q²M Polish Eccentric - 80mm 2-pack
  • Polishing pad voor het verwijderen van lichte lakdefecten
  • Speciaal ontworpen voor excentrische (Dual Action-) machines
  • Verkrijgbaar in twee formaten: 80 en 145mm
  • Hoogte: 20mm
€ 17.99
Menzerna
Medium Cut Pad - Diverse Afmetingen
  • Medium Cut polijstpad
  • Trapezevormige pad voor een optimaal contactoppervlak
  • Hoge kwaliteit klittenband
  • Verkrijgbaar in verschillende maten
€ 22.99
Nearly sold out
Offer
Rupes
D-A Intermediate Foam Pad
  • Intermediate polijstpad
  • Geschikt grof, fijn en éénstaps polijstwerk
  • Individueel verpakt in flow pack
Retail price: € 13.13 € 9.99
Scholl Concepts
Purple Compounding Pad - 145mm
  • Stevige polijstpad voor zwaardere polijstmiddelen
  • Verwijdert diepe swirls en schuurkrassen
  • Geschikt voor Dual Action- en roterende polijstmachines
€ 15.49
Blogs about this product
