Senza Acqua Piazza Drying Towel - 45x45cm
Art. nr. MSAP0101
Monello Senza Acqua Piazza - Compact drying with grand results
The Monello Senza Acqua Piazza is the compact and versatile sibling of the well-known large Senza Acqua drying towel. With a handy size of 45x45cm and a solid weight of 550 grams per square meter, this towel is ideal for precision work. Where a large drying towel can sometimes clumsily drag on the ground when drying lower parts, the Piazza offers the solution. It is the perfect partner for drying door jams, rims, mirrors, and bumpers.
Thanks to the ultra-soft microfiber structure, the towel not only absorbs a lot of water but is also safe for the paintwork. The finish with a soft satin edge prevents unwanted scratches during drying. Besides drying, this towel is also extremely suitable for safely buffing off waxes, sealants, or detailer sprays due to its softness. An indispensable, multi-functional towel for every car enthusiast with an eye for detail.
Product number: MSAP0101
Gram per vierkante meter: 550
  • 550 gsm
  • Size: 45 x 45cm
To dry small surfaces, fold the towel in half or into quarters to create a manageable cushion. Pat or wipe gently over the wet surface (such as mirrors or rims) to absorb the water. For buffing off wax: rub the haze of the product away with a clean, dry side using light, circular motions.
Tips Use a separate Piazza towel for rims and door jams than for the paintwork to prevent brake dust or grease from getting onto the clean paint. Wash the towel without fabric softener to maintain its absorbency.
1 - 3 of 20 reviews
Heel goed
Heel tevreden over deze doek. Gemakkelijk in gebruik en is superzacht. Ideaal voor de onderkant van je wagen zodat je niet met je (grotere) doek de grond aanraakt en die zo weer vies is.
Lander - 28/04/2025
Fijne doek
Super fijne zachte en handzame doek van mooie kwaliteit tegen een redelijke prijs, aanrader.
Charles - 30/11/2024
Valt tegen. Laat vezels achter
Doek al meerdere keren gebruikt en gewassen met speciaal wasmiddel. Droogt goed en heerlijk zacht, maar laat vezels achter op de lak. Dit is niet wenselijk.
Michel - 13/04/2024
Doppino Piccolo - Premium Drying Towel - 45x45cm
  • Droogdoek met gedraaide lus
  • Laat geen pluisjes achter
  • Maakt elk oppervlak in 1x droog
  • Sterk absorptievermogen
€ 7.99
Out of stock
Senza Acqua Piazza Trio Drying Towels - 45x45cm
  • Thick and soft microfiber drying towel
  • Easy to handle becaus of it's size
  • Also suitable for polishing or wiping waxes and sealants
  • Finished with a soft and scratch free satin edge
€ 16.99
Favorite
  • Soft microfiber towel
  • Intended to wipe your car in one go
€ 17.99
