- Compact soft microfiber towel
- Perfect for door jams
- Safe for paintwork
- Handy 45x45cm size
Monello Senza Acqua Piazza - Compact drying with grand results
The Monello Senza Acqua Piazza is the compact and versatile sibling of the well-known large Senza Acqua drying towel. With a handy size of 45x45cm and a solid weight of 550 grams per square meter, this towel is ideal for precision work. Where a large drying towel can sometimes clumsily drag on the ground when drying lower parts, the Piazza offers the solution. It is the perfect partner for drying door jams, rims, mirrors, and bumpers.
Thanks to the ultra-soft microfiber structure, the towel not only absorbs a lot of water but is also safe for the paintwork. The finish with a soft satin edge prevents unwanted scratches during drying. Besides drying, this towel is also extremely suitable for safely buffing off waxes, sealants, or detailer sprays due to its softness. An indispensable, multi-functional towel for every car enthusiast with an eye for detail.
| Product number: | MSAP0101 |
| Gram per vierkante meter: | 550 |
- 550 gsm
- Size: 45 x 45cm
To dry small surfaces, fold the towel in half or into quarters to create a manageable cushion. Pat or wipe gently over the wet surface (such as mirrors or rims) to absorb the water. For buffing off wax: rub the haze of the product away with a clean, dry side using light, circular motions.
Tips Use a separate Piazza towel for rims and door jams than for the paintwork to prevent brake dust or grease from getting onto the clean paint. Wash the towel without fabric softener to maintain its absorbency.
4 - 3 of 20 reviews
Hele goede droogdoek
Deze vorig jaar besteld en onlangs de set van 3 stuks na de goede ervaringen. Ik heb er alle vertrouwen in dat deze doeken mij net zo goed gaan bevallen. Ik gebruik de doek voornamelijk voor het drogen van de auto, maar wil nu ik er meer heb ook spraywax mee afnemen. De doek is inmiddels al meermaals gewassen, de individuele "haartjes" gaan wat aan elkaar klitten na het wassen, maar met opschudden voor gebruik wordt hij weer heerlijk zacht. Het mooie aan de witte doek is dat je duidelijk kan zien of de auto wel echt schoon is.
Topaankoop
Ik lees goede en negatieve reviews. In mijn gebruik ben ik alleen maar positief op dit moment. Het formaat is ook handig in gebruik maar meer dan 1 stuk hebben is aan te raden.
Prima doek
Gebruik deze in combinatie met de grote. Handig voor de lagere en kleinere delen van de auto.
