Senza Bordi Trio Edgeless Towels - 45x45cm
Art. nr. MSB0103
5.0 (11)
Monello Senza Bordi - Ultimate safety for the most fragile surfaces
The Senza Bordi is a premium microfiber towel specifically developed to prevent scratches on the most delicate surfaces. Because this towel is ultrasonically cut, stitched edges and hems are completely absent. This makes the towel pre-eminently suitable for very sensitive paints (such as soft solid paints) and scratch-sensitive high-gloss black interior parts, often called 'piano black'.
Where a normal towel with a stitched edge might still cause micro-scratches on these extremely soft materials, the Senza Bordi glides over the surface without risk. The density of the microfibers ensures safe absorption of residue when wiping off wax, sealant, or a detail spray. Due to the absence of an edge, pressure distribution is optimal.
Product number MSB0103
Color White
Dikte van de microvezeldoek Normaal 300 - 399 gram/m²
Durability Short
Randloos ontwerp Ja
Size Large
Suitable for application Afnemen coatings, Afnemen dressings, Afnemen glaze, wax en sealant, Afnemen interieurproducten, Afnemen polijstmiddel
Type of fiber Gesloten lus
  1. Fold the towel in four to create eight soft working surfaces.
  2. Apply minimal pressure to the surface; let the fibers do the work.
  3. Preferably use a lubricant (such as detail spray) when dry wiping.
  4. Flip to a clean side in time to prevent saturation.
Tips
  • Always wash these towels in a laundry bag to prevent damage to the ultrasonically cut edges in the washing machine.
  • Use these towels exclusively for the final finish (wax/sealant) and not for dirty work.
De Monello Senza Bordi Edgeless Towel heeft een afmeting van 45x45 cm, een handig formaat voor kleinere oppervlakken of voor wie liever een handzame doek gebruikt.
Was de Monello Senza Bordi Edgeless Towel op maximaal 40°C in de machine, zonder wasverzachter. Gebruik de Monello Senza Bordi Edgeless Towel alleen schoon om krassen of strepen te voorkomen en laat de Monello Senza Bordi Edgeless Towel aan de lucht drogen.
De Monello Senza Bordi Edgeless Towel is gemaakt van hoogwaardige microvezel met een dichtheid van 380 g/m², waardoor de Monello Senza Bordi Edgeless Towel zacht aanvoelt maar toch krachtig genoeg is om producten efficiënt op te nemen.
De Monello Senza Bordi Edgeless Towel is ideaal voor krasgevoelige lakken, delicate oppervlakken, glas, spiegels en kunststofdelen. Dankzij het randloze ontwerp glijdt de Monello Senza Bordi Edgeless Towel soepel en veilig over het oppervlak.
Het lasergesneden randloze ontwerp van de Monello Senza Bordi Edgeless Towel voorkomt scherpe randen die krassen op je lak of delicate oppervlakken kunnen veroorzaken. Zo kun je veilig en nauwkeurig werken.
Ja, de Monello Senza Bordi Edgeless Towel is perfect voor het afnemen van wax en sealants en voor het oppoetsen van polish. De gesloten microvezels van de Monello Senza Bordi Edgeless Towel nemen product efficiënt op en laten een streeploos resultaat achter.
Fijn!
Kreeg van Dennis deze aangeraden om bijzonder kwetsbaar materiaal in het interieur mee aan te pakken. Het type waar je beter alleen naar kijkt, maar soms toch iets mee moet. Dit samen met de spray en wipe onverdund afgenomen. Wel nog maar 1x gebruikt, maar tot zover tevreden!
Arjen - 14 December 2021
Top
Ik vind dit hele fijne doeken. De Senza Bordi gebruik ik om sealants af te nemen of om de lak op te poetsen. Deze zijn het geld echt waard.
Armin - 17 November 2021
Erg fijne doek om te gebruiken. Aanrader
Ric325i - 24 October 2016
Senza Bordi Edgeless Towel - 45x45cm
  • Laser-cut edgeless microfiber cloth
  • Closed fiber, perfect for wiping coatings
  • Particularly suitable for scratchy lacquers
€ 6,-
Q²M BaldWipe EVO - 40x40cm
  • All-Purpose-Towel geschikt voor vele doeleinden
  • Lasergesneden vezels
  • Randloos ontwerp
  • Formaat: 40 x 40 cm
€ 6.99
Blogs about this product
