Först Citrus Pre-Cleaner-5000ml
Art. nr. C08STF050C
The first choice for tough cleaning jobs
When your car is really dirty, or it's time for spring cleaning, Först, a citrus Traffic Film Remover (TFR), makes the task easy.
Formulated with natural orange oil, it not only boosts cleaning power but also smells amazing!
Apply undiluted to areas that need extra attention, let the product sit for a moment to work its magic, and then rinse thoroughly with water.
Först Citrus Pre-Cleaner has more cleaning power than Snö Snow Foam because it doesn't have added air, has a higher pH, and works at full strength. The downside is that your wax and sealant may not tolerate it as well.
It's often unnecessary and wasteful to spray the entire car with Först Citrus Pre-Cleaner. Use it only on the areas that really need it, usually the lower parts of the car, like bumpers and sills. Först Citrus Pre-Cleaner is also perfect for cleaning door jambs or under the hood.
Product number: C08STF050C
H315: Causes skin irritation.
  • Spray Först Citrus Pre-Cleaner evenly on the areas you want to treat.
  • Allow the product to work for 2-5 minutes, then rinse it off with water, preferably using a pressure washer.
  • Do not let it dry.
Effective pre-wash that lifts heavy road grime and insects with minimal effort, pleasant citrus scent, economical to use and ideal for winter or dirty areas; sprays on, short dwell time, rinse off with high pressure for excellent, repeat-worthy results.
6 - 3 of 18 reviews
Doet weinig
Als sample gekregen bij een bestelling en leek mij ideaal om aangekoekte vliegjes op de neus van de auto mee te behandelen. Volgens gebruiksaanwijzing toegepast maar merk eigenlijk geen verschil, ik moet nog even hard boenen. Voor het normale vuil zie ik geen toegevoegde waarde, dat gaat er al prima vanaf met goede shampoo e.d.
Wouter - 09/09/2021
top!
gebruik m voornamelijk met kouder weer icm met een spray sealant om de auto toch schoon te kunnen houden als het vriest. bijna alles gaat er af (inclusief je wax/sealant) maar in tegenstelling tot vele andere pre-wash is je auto wel voor 90% schoon.
Jelle - 24/12/2020
Absolute aanrader!
Ideaal voor de mensen die geen snowfoam hebben. Hiermee kun je het hardnekkigste vuil van je auto verwijderen zonder het aan te moeten raken. Denk hierbij aan de wielkasten en onder de dorpels van je auto. Eigenlijk zou iedereen dit in zijn collectie moeten hebben. Dit product kan je uit de brand helpen.
Tessa - 21/12/2020
Alternative products
Last chance
Auto Finesse
Citrus Power Bug and Grime Remover
  • Effectieve insecten- en vuilverwijderaar
  • Mild voor je laklaag
  • Gemakkelijk in gebruik, schrobben niet nodig
  • Kant-en-klare formule
€ 15.99
Has been discontinued
Valet Pro
Citrus pre-Wash
  • Versatile All Purpose Cleaner
  • For exterior, interior, and carpet
  • pH value 9.5, so not aggressive
  • Fresh citrus scent
€ 13.75
Offer
IK Sprayers
HC TR 1 - 1000ml
  • Professionele sprayfles
  • Geschikt voor oplosmiddelen
  • Maatverdeling per 50ml
  • Kleurindicator
Retail price: € 14.50 € 12.49
Last chance
Stjärnagloss
Först X Citrus Pre-cleaner - 1000ml
  • Krachtige Traffic Film Remover (TFR)
  • Geconcentreerde versie van de Först
  • Ideaal voor het reinigen van een zwaar vervuild exterieur
€ 20,-
