Tips & tricks / Reviews
Is Dodo Juice’s cult status still deserved?
By: Tim 7 min read
Fles
Dodo Juice is one of those brands that almost every detailer has come across at some point. Bottles in bright colors, names you either love or just don’t get, and scents that make your driveway smell more like a candy store than a clean car. The brand has built up an enormous cult following and has been, for many, their first step into the world of serious detailing.
But times change. The market is busier than ever, technology keeps moving forward, and new brands and products keep appearing. This raises an interesting question: does that cult status still hold up today, or is Dodo Juice mostly riding on nostalgia? With no less than 76 products in their lineup, there’s certainly plenty to take a closer look at.
Check out our video about Dodo Juice below!
The Popular Products
Within the Dodo Juice lineup, there are fifteen products that clearly stand out in terms of popularity. That already says a lot. These products aren’t just bought for their looks or scent—they’re trusted because they deliver on their promises.
A prime example is Future Armour, a spray sealant you can apply on a still-wet car. This type of product fits perfectly into the modern detailing routine, where speed and convenience are becoming increasingly important. Just spray, rinse, and your paint immediately gets extra protection and water repellency.
On the other hand, there’s Born to Be Mild, a shampoo with an extremely high concentration. This is the kind of product that seasoned detailers love. No additives, fully residue-free, and safe for delicate paints and matte finishes. You use a little, but get many washes out of it.
For clay work, Born Slippy is a true customer favorite. This dedicated clay lubricant gives a bit more assurance than a quick detailer spray. The product is extremely smooth, lightly foaming, and makes clay work safe and predictable—even for beginners.
Plank, Volwassene, Mannelijk, Man, Persoon
Scent, Ease of Use, and Effectiveness
One of the most recognizable features of Dodo Juice is its scent. Mint Condition, a detailer spray from the newer line, not only leaves a beautiful shine but also smells remarkably fresh. The same goes for Clearly Menthol, a streak-free glass cleaner that treats your nose to a refreshing mint aroma. It may not be a dealbreaker, but it certainly adds to the enjoyment while working.
For interiors, there’s Supernatural Leather Cleaner, a powerful leather cleaner especially suited for sturdy leathers, like those found in many sporty or luxury cars. With more delicate leathers, it’s always wise to test first. The cleaner works effectively without leaving any residue, preparing the leather perfectly for a sealer, such as the Supernatural Leather Sealer. This product is suitable for both leather and vinyl, providing a solid base for a long-lasting, beautiful interior finish.
Sour Power is a more accessible shampoo with added protection. Less concentrated than Born to Be Mild, but offering extra gloss and light water repellency. Perfect for maintenance washes when you want a bit more shine without extra steps.
From Classics to Surprises
Lime Prime is perhaps the most talked-about product in the lineup. A cleaner and glaze in one, and indeed: you love it or you hate it. Use too much, and wiping it off becomes tricky. Use it thinly and with control, and you get deeper paint, more gloss, and a surprisingly crisp result—all in one step.
For heavy contamination, there’s Ferrous Dueller, a pH-neutral de-ironizer that removes tiny metal particles from any surface—from brake dust on wheels to rail dust on paint and glass. The product is slightly thicker than average, clings longer, and can therefore work deeper, providing a more thorough result than similar products. Extra active agents create a cleaner surface and better prepare the car for the next detailing step. Effective, but the characteristic smell of iron removers is present, so not ideal for sensitive noses.
Apple iFoam shows that maintenance products don’t have to be boring. This pH-neutral snow foam is safe for wax and sealants and smells wonderfully of green apples, making cleaning fun. iFoam is used as a pre-wash or for a touchless wash on lightly soiled, well-protected cars. The thick foam has enough time to loosen and lift dirt before you continue with a wash mitt, helping to prevent swirls and scratches. Apple iFoam offers a safe and effective way to combine daily maintenance with the preservation of protective layers.
For tires and trim, Dark Matter is a dressing with a satin finish. Not an over-the-top glossy look, but a natural appearance that appeals especially to fans of the OEM-style finish.
Essential Accessories
Not everything comes in a bottle. The Mint Merkin glass cloth ensures that glass cleaners can do their job streak-free. This waffle-weave cloth absorbs a lot of moisture, has a bit more “bite,” and removes grease and dirt from windows more effectively than standard cloths. Perfect when used with Clearly Menthol glass cleaner for flawlessly clear windows. Thanks to its durable material, the Mint Merkin can also be used for polishing metal—but note: after using it on metal, don’t use it on glass to avoid scratches or contamination.
The Blue Roo microfiber applicators are true all-rounders for applying and buffing liquid polishes, glazes, and pre-wax cleaners. These soft pads combine microfiber and foam and feature a handy “pocket” for your fingers, giving you better grip and precise control over the product. They come in a set of two and make manual work much easier and more accurate.
The Supernatural Detailing Clay is a medium-grade clay that’s easy to knead. It’s more effective and firmer than the Supernatural Fine Clay, but only causes marring on softer paints or when a lot of pressure is applied. Most of the time, you’ll notice that you work faster and more efficiently, while the clay simultaneously cleans the surface thoroughly. An excellent choice for anyone looking to add a reliable and effective clay to their detailing routine.
Accessoires, Polshorloge, Persoon
Lichaamsdeel, Vinger, Hand, Persoon, Woondecoratie
Practical Test: What’s Left Behind?
In the practical test, three products really stand out. The powerful tire and trim cleaner Pneu Look shows how quickly dirt can be lifted, sometimes even without brushing—making it surprisingly economical to use. The product is specially designed to thoroughly clean tires and unpainted trim, which is essential for achieving the best results when applying a tire dressing.
The citrus-based formula effectively removes grease, oil, and stubborn grime while leaving a fresh scent during use. Pneu Look provides a perfectly clean base, allowing dressings to adhere better and last longer. For heavily soiled surfaces, the treatment can be repeated. The product is intended for unpainted trim and rubber only; high-gloss painted surfaces should be left untouched.
Lichtmetalen velg, Autowiel, Spaak, Band, Wiel
There’s also Drynamo Beading Rinse Sealant, a drying aid or “wash sealant” that you apply during rinsing to make drying faster and easier. The product promotes water beading, reduces friction while drying, and helps prevent swirls.
At the same time, it leaves a thin protective layer that adds extra gloss, makes it harder for dirt to stick, and simplifies future washes. With effects lasting 2 to 4 months, Drynamo perfectly meets the needs of the modern detailer: faster drying, a smoother paint feel, and extra protection—all in one step.
Auto, Autowasserette, Windscherm, Polshorloge, Persoon
Ring, Auto, Windscherm, Man, Persoon
Then there’s Lime Prime Fine Cut Prep Polish, a pre-wax cleaner that shows why it has remained so popular. It removes contaminants from the paint pores, light oxidation, swirls, and water spots, leaving the paint noticeably deeper in color and remarkably smooth to the touch.
Lime Prime can be used by hand or machine, and thanks to its very fine abrasives, it’s suitable for modern high-gloss medium to hard paints. Lime Prime perfectly prepares the surface for wax or sealant, enhances gloss, and ensures the final result is optimal.
Auto, Windscherm, Coupé, Spaak, Persoon
In Short
Dodo Juice may not offer everything the market has today, but what they do, they still do well. Not every product will be for everyone, but the combination of effectiveness, enjoyable use, and recognizable character explains why its cult status hasn’t come out of nowhere.
We hope this blog has helped you get started so you can dive into Dodo Juice yourself—and become a true CleanRider in the process.
Skip product gallery
Bilt-Hamber
Touch-Less Snow Foam - 1000ml
  • Zeer effectieve prewash foam
  • Geschikt voor foamlans, handfoamers en zelfs sprayers
  • Biologisch afbreekbaar
  • Gemiddelde PIR van 1%
€ 16.99
In stock
Offer
Acquafobia - 500ml
  • Easy to use spraycoating
  • Sustainable up to 12 weeks
  • Extremely water repellent
Retail price: € 16,- € 14,-
In stock
Last chance
AVA
Evolution series P60 145 bar hogedrukreiniger - L-pack
  • Uitgebreide, krachtige hogedrukreiniger
  • Geleverd met diverse hulpstukken en met staal versterkte slang
  • 145 bar/500 liter per uur
  • Aluminium pomp met 4 cilinders
€ 389,-
Has been discontinued
Read more
By: Vincenth
