Q²M CeramicDetailer - 500ml
Art. nr. GY-CD05
Gyeon Q²M CeramicDetailer is the perfect maintenance product for ceramic-coated surfaces, combining the best of both worlds: spray sealants and traditional quick detailers. This is exactly where the name CeramicDetailer comes from!
Q²M CeramicDetailer is just as easy to use as the well-known Q²M QuickDetailer. It can be applied to both dry and wet paint, and when used on wet surfaces, it also serves as a handy drying aid. Q²M CeramicDetailer is suitable for all types of paint, including coated surfaces.
Product number: GY-CD05
  • Contents: 500ml or 1000ml
  • Usage: 40-50ml per car
  • Durability: Up to 6 weeks
  • Suitable for All Types of Paint
  1. Spray a generous amount of product onto a damp microfiber cloth.
  2. Wipe the product over the surface.
  3. Perfect the finish with a dry Q²M SoftWipe.
A versatile ceramic detailer that’s easy to apply, leaves paint super smooth with deep gloss and excellent beading, boosts coatings and aids drying — long‑lasting, pleasant smelling and suitable for coated or uncoated cars. Highly recommended.
7 - 3 of 26 reviews
Top product
Erg fijn product dat de lak lekker glad maakt en hij is gemakkelijk verwerkbaar. Ruikt bovendien ook nog prettig.
A - 31/03/2022
Glad en glans
Deze aangekocht om eens wat nieuws te proberen geeft een goed resultaat op lak en op glas en makelijk te verwerken
Jens - 17/03/2022
Geweldig!
Een van de beste quick detailer die ik heb gebruikt. Erg makkelijk in gebruik. En de lak voelt na gebruik super glad aan. Doet ook zeker wat met de glans!
RoyR - 04/03/2022
  • The Perfect Boost for Your Paint
    Q²M CeramicDetailer
Ceramic maintenance made easy
Preserve the ultimate protection
The Gyeon Q²M CeramicDetailer is specifically designed for maintaining ceramic-coated vehicles. Thanks to its SiO₂-enriched formula, this detailer helps extend the protection and hydrophobic properties of the coating. As a result, the paint stays cleaner for longer and retains its deep gloss. The product adds extra slickness and enhances water beading, making it harder for dirt and water to adhere. This keeps your coating in top condition without needing to apply a new protective layer constantly.
Spray, wipe, and done
Super easy to use
With Gyeon Q²M CeramicDetailer, you save time and effort. The formula is incredibly easy to work with: simply spray it onto the paint and wipe it off with a microfiber cloth for a streak-free finish. It also works great as a drying aid, as it has water-repellent properties that help remove water droplets from the surface quickly. This prevents water spots and speeds up the drying process. Whether you want a quick refresh or an effortless drying solution after washing, this detailer gets the job done.
Suitable for every car, no discrimination
Universal perfection
Whether your car has a classic solid paint, a modern metallic finish, or a deep pearl effect, Gyeon Q²M CeramicDetailer is ready for it. The product is safe to use on all paint types, coated or uncoated, and always delivers a smooth and glossy finish. Even if your car isn’t ceramic-coated, you’ll still benefit from its hydrophobic and dirt-repelling properties. This way, every car enjoys a professional look without the hassle of complicated application processes.
Offer
Sonax
Xtreme Ceramic Ultra Slick Detailer - 750ml
  • Snelle detailer met parelend effect
  • Geschikt om lichte vervuiling te verwijderen
  • Frist bestaande coatings op
  • Boost glans
Retail price: € 16.99 € 11.99
Collinite
Slickr 3 in 1 Ceramic Detailer - 473ml
  • Multiple use detailer
  • Super-hydrophobic effect
  • Boost gloss
  • Use as drying aid
€ 17.99
Offer
Turtle Wax
Hybrid Solutions Ceramic 3-in-1 Detailer - 500 ml
  • Gemakkelijke detailer
  • Te gebruiken tussen de wasbeurten door
  • Houdt het voertuig langer schoon
Retail price: € 25.99 € 17.99
Nearly sold out
Meguiars
Hybrid Ceramic Detailer - 768ml
  • Perfect voor tussen de was- en waxbeurten door
  • Voor het verwijderen van lichte vervuiling en stof
  • SiO2-keramische bescherming zorgt voor extreme waterbeading
Retail price: € 30.56 € 24.49
