Green Star - All Purpose Cleaner - 1000ml
Koch Chemie Green Star - The Universal Cleaning Champion
Koch Chemie Green Star is a highly concentrated and versatile cleaner for a wide range of applications. The powerful, alkaline formula is free from phosphates and solvents, ensuring high material compatibility with sensitive components. Thanks to its special composition, the product is biodegradable.
Its excellent dirt and oil-carrying properties make Green Star the ideal choice for cleaning both the interior and exterior of vehicles, as well as workshop floors and engine bays. A true all-rounder for any cleaning task.
Note: sprayer not included.
Product number: 291001
H315: Causes skin irritation.
Corrosion: Corrosive
  1. Dilute the product according to the level of contamination.
  2. Apply the solution to the surface to be cleaned.
  3. Allow the product to act for a short time, but do not let it dry.
  4. Rinse thoroughly with a pressure washer or wipe off with a damp cloth.
  • Exterior & engine cleaning: 1:5 to 1:30
  • Interior & textile cleaning: 1:10 to 1:20
  • Workshop & industrial floors: 1:40 to 1:120
Tips
  • Always test the product on an inconspicuous area first to check for material compatibility.
  • For textile cleaning in the interior, it is recommended to use a wet vacuum cleaner to completely remove product residues.
Versatile, powerful all-purpose cleaner: great as a pre-wash, for wheels, tyres, interiors and household jobs. Dilutable for different uses, effective at 1:10–1:20, fresh scent, good foam, excellent value and highly recommended.
5 - 3 of 17 reviews
Prewash koning
Ik gebruik het als een hele heftige prewash 1:10 mix. Let op om het niet te lang erop te laten. Instructies goed doornemen het is koch chemie he, super disciplinair die oosterburen. Werkt super goed dat wel.
Kayhan - 23/10/2025
Tot nu toe super
Ik ben nog een beetje aan het proberen met de mengverhouding. Wat voor mij het beste werkt. Maar ik ben erg onder de indruk tot nu toe
Andrew - 16/10/2025
Wat een geweldig product!
Tot op heden ben ik verknocht aan de Bilthamber Surfex HD multireiniger. Wat ook echt een zeer goede APC is. Na het lezen van diverse goede reviews van Koch Chemie GS ook maar eens een literfles aangeschaft. En ik kan alleen maar concluderen dat het inderdaad super is. Het grootste voordeel t.o.v. BH surfex HD is dat het ook nog eens lekker ruikt. Zeker voor het interieur is dat een plus. Momenteel alleen nog maar gebruikt als bandenreiniger in een verhouding van 1:5. Dit werkt grandioos. Banden zijn na eenmalig behandelen brandschoon. Ik ga het zeker voor meerdere toepassingen gebruiken. Kwaliteit is absoluut te vergelijken met de BH surfex HD.
Martin - 06/10/2025
