Faro - LED Zoombare Inspectielamp + 2400 mAh Li-Ion Accu
Art. nr. BMON18
Monello Faro
The Monello Faro is the ideal lamp to inspect your paintwork for swirls, scratches, holograms and other paint defects. Thanks to the zoom lens you can create a narrow bean as well as a very wide beam of light to inspect a variety of paint defects.
The Faro an indispensable tool when it comes to inspecting a car before treatment and during polishing to check if all paint defects have been removed. Faro has a handy size (145mm) and made of high quality lightweight aluminum with beautiful accents. The smooth zoom mechanism can be managed with just one hand, allowing for very quick inspection between polishing. The Faro is also equipped with grip structure for better grip and has a wrist strap to prevent falls during inspection.
Monello Li-ion rechargeable battery
Monello Li-ion rechargeable battery with 2400mAh capacity for use in combination with the Monello Faro LED Inspection Lamp. Li-Ion has a very low self-discharge rate which means that the battery will remain good even with low usage. The battery can also be charged without any problems if it is half empty.
Product number: BMON18
Includes:
  • Monello Li-ion rechargeable battery
  • Faro - LED light
Compact, robust aluminium inspection torch delivering very bright, adjustable beam and long battery life. Easy to hold, handy wrist strap and USB charging; versatile for polishing, car paint inspection and everyday use. Great value as a complete kit.
3 - 3 of 10 reviews
Stevige zaklamp met goed lciht
De zaklamp voelt stevig en geeft een flinke bundel licht. Voldoende om te inspecteren en doordat je met de lens kunt schuiven kun je de concentratie aanpassen indien nodig. Zo is op een donkere lak de meest verspreidde stand voldoende en op een lichte lak, waar defecten lastiger te zien zijn, de meest gebundelde stand het beste. Omgekeerd werkt de meest gebundelde stand op een donkere lak veelal verblindend. Als zaklamp is die ook heel fijn omdat hij ver straalt en flink verlicht! De bouwkwaliteit is dik in orde: stevig en met goede grip. Het koortje is een mooie toevoeging waarmee hij om de pols gezekerd kan worden. Ook dit koort voelt degelijk aan en doordat het een rond koord is snijdt deze ook niet. De accu gaat lang mee en bij hobbymatig gebruik dus weken. Laden gebeurd met een laadstation welke via een USB kabel gevoed moet worden. De mogelijkheid richting het stopcontact wordt niet meegeleverd dus moet je daarvoor bijvoorbeeld een telefoonlader gebruiken. Dit vind ik wel jammer want ik had het graag kant en klaar gezien.
Robin - 07/05/2021
Prima inspectielamp
Mooie lamp om de lak de inspecteren op oa swirls. Hoge lichtopbrengst. Makkelijk in gebruik. Stevige constructie. In combinatie met accu lange lichtopbrengst.
Huub Paffen - 31/03/2021
Prima lamp prijs/kwaliteit
goede licht opbrengst, wel is aan te raden de extra accu bij te bestellen. Door de extra accu gaat de lamp langer mee. zit goed in elkaar en is makkelijk vast te houden. mooie opbergzak zou handig zijn.
Giovanni - 22/03/2021
Favorite
Luce Inspection Light
  • Inspectielamp met twee leds
  • Traploos dimbaar
  • Diverse magneten
  • Ook te gebruiken als powerbank
€ 36.99
