Guanto Puro Clay Mitt
Art. nr. MGP0101
Monello Guanto Puro Grade Clay Mitt - Super fast paint decontamination
This special wash mitt is the modern and fast alternative to the traditional clay bar. The Monello Guanto Puro Clay Mitt features an advanced rubber polymer layer on one side that effectively removes bonded contaminants from the paintwork. This includes tar, tree sap, industrial fallout, and overspray that do not disappear with a normal wash. Due to the large surface area of the mitt, this process is significantly faster than using a small piece of clay.
The other side has a mesh structure and is perfect voor removal of insect when washing the car. Use Monello Ciao Insetti insect remover for optimal effect.
The major advantage of this mitt is its durability; should the mitt fall on the ground during use, it can simply be rinsed off and used again. With traditional clay, the product must be discarded. This polymer rubber is a 'Fine Grade' variant is relatively mild on the paint, but when using clay products there is always a slight risk of light marring (micro-scratches), so it is advisable to lightly polish the car or treat it with a cleaner after use. The mitt is less suitable for very tight corners where a small piece of clay can reach.
Product number: MGP0101
  1. Wash the car thoroughly to remove all loose dirt.
  2. Prepare a bucket with water and a generous amount of shampoo (lubricant).
  3. Dip the mitt into the soapy water and glide the rubber side over the wet paintwork.
  4. Rub without applying pressure until the surface feels smooth and rinse the mitt regularly.
Tips
  • Use the Clay Mitt on the car windows before first use; this helps to 'break in' the rubber layer and make it pliable.
  • Always ensure sufficient lubricant (shampoo or clay lube) to minimize the risk of scratches; the mitt should never drag 'dry' over the paint.
Ja. De mitt is ontworpen als alternatief voor het traditionele kleiblok en werkt veel sneller door het grotere oppervlak. Voor nauwkeurige hoekjes of extreem vervuilde plekken kan een kleine clay bar handig blijven.
De mitt is herbruikbaar zolang de polymerenlaag intact blijft. Spoel hem na elk gebruik grondig uit en laat hem volledig aan de lucht drogen voordat je hem opbergt.
De polymeerlaag is een fine grade variant en relatief mild voor de lak. Toch bestaat er bij elk clay-product altijd een kleine kans op lichte marring. Daarom raden we aan de lak na gebruik licht te polijsten of te behandelen met een cleaner of wax.
Het is het beste om de mitt na gebruik met schoon water uit te spoelen en aan de lucht te laten drogen. Machinewassen kan de polymerenlaag beschadigen of verkleuring veroorzaken.
Ja. De andere zijde heeft een mesh microvezelstructuur die ideaal werkt voor het verwijderen van insecten. Voor een nog beter resultaat kun je de mitt combineren met een insectenverwijderaar zoals Monello Ciao Insetti.
2 - 3 of 5 reviews
Makkelijk
Top werkt een stuk sneller als de old school klei Dat is zeker maar als de vervuiling zwaarder is dan val ik toch weer terug op het oude vertrouwde stukje klei
Rémon - 29/05/2026
Fijne klei mitt
Doet zijn werk goed. Mijn eerste echte keer kleien ( zonder polijsten achteraf ). Makkelijk in gebruik. Heeft zeker z'n werk gedaan. De mesh zijde niet gebruikt. Op een steel grey / nardo grey achtige Skoda Octavia geen gekke marring of krasjes gemaakt. Erna met PB white diamond behandeld, zeer mooi resultaat.
Guido - 22/03/2026
  • Een echte alleskunner
    Onze blauwe krokodil
Vertrouwde kwaliteit
Gemaakt in de VS
Wel zo handig
Beide zijdes tegelijkertijd
Goed gemaakt
Stevige nylon borstelharen
Dolce Verde klei - 250 gram
  • Fine cleaning clay for excellent cardetailing
  • Easy to model
  • Fits perfectly for easy handeling
€ 21.99
Last chance
Flexipads
Fine Grade Clay Mitt
  • Snel en eenvoudig te gebruiken
  • Ideale voorbereiding voor het polijsten
  • Verwijdert vastzittende vervuiling
  • Gaat tientallen keren mee
€ 29.99
Has been discontinued
Last chance
The Rag Company
Ultra Clay Towel - 30x30cm
  • Speciale polymeer kleidoek
  • Werkt sneller dan traditionele klei
  • Verbeterde hechting van wax & sealant
  • Duurzaam & gaat lang mee
€ 36.99
Nearly sold out
Collinite
Super Clay Towel - 30x30cm
  • High quality clay towel
  • Use with shampoo or claylube
  • Treats 60+ vehicles
  • Size: 30x30cm
  • € 36.99
    Guanto Puro Clay Mitt in our blog
    Removing insects from your car? Here’s the smart way to do it
    Nothing is more annoying than a front bumper full of splattered insects after a highway drive. Did you know those tiny remains can cause serious damage to your paintwork?
