Earn Polishpoints with every order for extra discounts! Discover more!
Spazzola Doppio - Premium Brushes Horsehair & Nylon
Art. nr. MPD0102
The Monello Spazzola Doppio brush set consists of two high-quality brushes: a soft horsehair brush (Monello Peli) and a firm nylon brush (Monello Riccio). This combination makes the set ideal for thoroughly cleaning leather, plastic, convertible tops, floor mats, and other interior surfaces. With the right brush for each surface, you can work more precisely and safely, protecting delicate materials from damage.
Both brushes feature a luxurious 120 mm wooden handle with an engraved logo and rounded ends. Thanks to their compact size and ergonomic design, the brushes feel comfortable in your hand, allowing you to work for extended periods without fatigue. Perfect for cleaning small or hard-to-reach areas such as seams, crevices, and corners.
Monello Peli – soft horsehair brush
The Monello Peli is a soft horsehair brush, ideal for safely cleaning leather, fabric, vinyl, and plastic. The 17 mm long bristles from the handle provide precise, gentle treatment of delicate surfaces. The brush works well with almost all common leather and interior cleaners and leaves no scratches or streaks.
Monello Riccio – firm nylon brush
The Monello Riccio has firmer 18 mm nylon bristles from the handle, making it perfect for heavily soiled surfaces such as dashboards, floor mats, convertible tops, and other interior parts. The brush works excellently with all standard interior and leather cleaners, all-purpose cleaners, and convertible top cleaners.
Care and usage tips:
  • Always rinse the brushes with water after use to remove dirt and cleaning products.
  • Allow the brushes to dry completely before storing; do not store them wet to prevent mold or deformation of the bristles.
  • Use the correct brush for each surface: the soft horsehair brush for delicate surfaces, the nylon brush for heavily soiled or more robust surfaces.
In short, the Monello Spazzola Doppio is a durable, versatile, and comfortable brush set that helps you clean your car interior thoroughly and safely. Perfect for car enthusiasts who value precision and quality.
Product number: MPD0102
  • Wooden handle (120mm) with rounded ends
  • Rinse the brushes thoroughly after use.
  • Do NOT store damp
Ja, dankzij het compacte formaat en de luxe houten handgreep van 120 mm met afgeronde uiteinden liggen de borstels prettig in de hand en kun je er lang mee werken zonder vermoeidheid.
Spoel de borstels na gebruik schoon met water en laat ze volledig drogen. Bewaar de borstels nooit vochtig, zodat de haren hun vorm behouden en er geen schimmel ontstaat.
De Monello Peli is een zachte paardenhaarborstel voor gevoelige oppervlakken zoals leer, stof en vinyl. De Monello Riccio is een nylonborstel met stevigere haren voor zwaarder vervuilde oppervlakken zoals dashboards, vloermatten en cabriodaken.
De Monello Spazzola Doppio is ideaal voor het reinigen van leer, kunststof, cabriodaken, vloermatten en andere interieuronderdelen van je auto. Met de zachte paardenhaarborstel reinig je delicate oppervlakken, terwijl de nylonborstel geschikt is voor zwaarder vuil.
Ja, de Monello Spazzola Doppio kan gebruikt worden met vrijwel alle gangbare leer- en interieurreinigers, all-purpose cleaners en cabriodakreinigers.
Ja, gebruik de zachte paardenhaarborstel (Monello Peli) voor delicate materialen zoals alcantara, leer en andere krasgevoelige oppervlakken om veilig schoon te maken zonder strepen of beschadigingen.
The Monello brush set is compact yet effective for cleaning various surfaces, particularly in car interiors. Users appreciate the quality and softness of the bristles, which are suitable for delicate materials. However, some find the small size challenging for larger areas, potentially causing hand strain. Overall, it offers good value for money.
Compact, hoogwaardige dubbelborstelset die perfect werkt voor interieur, leer, alcantara en cabriodaken. Zachte paardenhaar en stevige nylonborstel reinigen grondig, liggen prettig in de hand en zijn duurzaam — ideaal voor hoekjes en delicate oppervlakken.
11 - 3 of 37 reviews
Borstels
2 mooie borstels eentje van paardenhaar voor bijv cabriodaken En de andere is nylon denk ik? Wat harder werkt gemakkelijk voor cabriodaken en stoelen / matten om het te reinigen Of voor te behandelen
Niels - 31/12/2020
Okay
Ze zijn vrij klein, wat eigenlijk handiger is dan je zou denken. Beide borstels zijn relatief zacht, wat fijn is voor het materiaal. Zo klein kan kram in je handen opleveren als je grote oppervlakten te lijf wilt gaan, wat ik dan ook af zou raden met deze borsteltjes.
Floris - 09/04/2020
Schijn bedriegt
De borstels lijken in eerste instantie klein, hoe meer je ermee werkt. Des te meer je ze begint te waarderen. perfect voor het schoonmaken van het lederen interieur.
Lars - 02/04/2020
  • Two brushes, everything clean.
Two brushes, every surface.
Complete interior set
The Monello Spazzola Doppio comes with two brushes: a soft horsehair brush for delicate surfaces such as leather, fabric, and plastic, and a nylon brush for tougher dirt on mats, dashboards, and convertible tops.
This way, you always have the right brush at hand, no matter which surface you’re cleaning. Perfect for a thorough, precise cleaning of your entire interior.
Comfortable in hand, easy to use.
Compact and ergonomic
Thanks to its compact size and luxurious 120 mm wooden handle with rounded ends, the Monello Spazzola Doppio feels comfortable in your hand.
You can work with it for extended periods without fatigue, while the ergonomic design ensures a firm grip and full control when cleaning small or hard-to-reach areas.
Long-lasting enjoyment of your brush set.
Durable and versatile
The Monello Spazzola Doppio is built to last. Simply rinse the brushes with water after use and let them dry completely.
The horsehair brush works safely on delicate surfaces, while the nylon brush is strong enough for heavier dirt. This gives you a durable, versatile set suitable for almost all interior cleaners, leather cleaners, and convertible top products.
Last chance
Carclean.com
Interieur borstel - Paardenhaar
  • Geschikt voor leer, vinyl en textiel
  • Vastzittend vuil komt eenvoudig los
  • Een abolute must voor elke auto detailer
  • Amerikaanse borstel
€ 16.99
Has been discontinued
Q²M LeatherBrush
  • Borstel voor het reinigen van leer.
  • Gemaakt van paardenhaar.
  • Ergonomisch handvat voor optimale grip.
  • Perfect voor gebruik i.c.m. Q²M LeatherCleaner Mild en Strong.
€ 4.99
Carclean.com
Carpet & Upholstery Brush
  • Interieurborstel met stugge, krasvrije borstelharen
  • Ideaal in combinatie met Mothers Carpet & Upholstery spray
  • Lichtgewicht, ergonomisch ontwerp
€ 5.99
Nuke Guys
Interieurborstel - small - Nylon
  • Interior brush with wooden handles
  • Suitable for all interior surfaces
  • Available in different sizes
€ 5.99
Offer
Meguiars
Carpet & Interior Brush
Retail price: € 18.92 € 15.19
Nearly sold out
Last chance
Valet Pro
Upholstery Brush
  • Handige borstel voor het interieur
  • Speciaal voor tussen stoelen, deuren en voetpedalen
  • Lange haren
€ 21.50
Last chance
Stjärnagloss
Viskelaer Leather and Fabric Brush
  • Interieurborstel met nylon haren
  • Verhoogt de effectiviteit van een interieurreiniger
  • Formaat: 170x60x50mm
€ 15,-
Dodo Juice
Hairy Palm Leather and Fabric Brush
  • Ergonomische borstel voor leer
  • Natuurlijke haren
  • Ook voor tapijt en andere stoffen
€ 17.49
Nearly sold out
Spazzola Doppio - Premium Brushes Horsehair & Nylon in our blog
How to Clean and Protect Your Convertible Top: The Ultimate Guide
Driving top-down is the ultimate feeling of freedom, but your convertible top takes a beating. From green algae growth to stubborn bird droppings: how do you get that fabric roof back to mint condition?
