Bird Sh#t Remover - 473ml
- Effective bird dropping remover
- Safe for car paint
- Retains existing wax layer
- Works within seconds
Poorboy’s World Bird Sh#t Remover - Fast and safe bird dropping removal.
Bird droppings contain acids that can permanently damage car paint. This spray is developed to safely and instantly loosen bird droppings, insect splatter, and tree sap. The liquid works within seconds, allowing baked-on dirt to be easily wiped away. No scratches occur during cleaning and the existing wax or protective layer remains completely intact.
The formula can be used without risk on paint, glass, plastic, and vinyl. Due to the fast action, paint damage is effectively prevented. For stubborn or deeply etched contamination, a second treatment is sometimes necessary. The product thoroughly removes the contamination, but does not repair damage already etched into the paint.
The 946 ml bottle has no sprayer.
| Product number: | PB-BSR16 |
Spray the liquid directly onto the contamination.
Allow the formula to penetrate for 5 to 10 seconds.
Gently wipe the dirt away with a clean microfiber towel.
Buff the surface with a clean section of the towel.
Tips
For heavily dried residue, place a soaked microfiber towel on the spot for one minute to thoroughly loosen the dirt.
Keep the spray bottle together with a clean towel in the vehicle to act immediately upon new contamination.
The product is generally well-received for effectively removing bird droppings from vehicles, with many users noting its pleasant scent and ease of use. However, some reviewers mention it is too liquid and can leave streaks or require multiple applications on vertical surfaces. Overall, it is considered a must-have for car owners.
4 - 3 of 37 reviews
Sprayer is matig, maar de vloeistof werkt goed
Even getest op een paar dagen oude droppings op de auto van mijn buurman en ging er verbazend soepel vanaf (wel 3 keer sprayen nodig, maar het was ook flink ingebrand). De spray doet alleen een straal en is lastig te doseren, dus als je een betere hebt liggen zou ik die overzetten.
Kan niet meer zonder
Had er weinig verwachtingen van, maar het werkt echt goed en ook nog eens snel. Hardnekkig vogelpoep moet je meerdere malen sprayen en wegvegen, wat ik niet erg vind.
Werkt prima, wel behoorlijk vloeibaar
Het product weekt goed los, maar op vertikale vlakken moet wat vaker herhaald worden omdat het er eigenlijk direct vanaf loopt. Op insectenresten lijkt het dan weer nagenoeg niets te doen, maar goed het is dan ook bird sh#t remover.
