Earn Polishpoints with every order for extra discounts! Discover more!
Bold N Bright Tire Dressing - 473ml
Poorboy's World Bold N Bright - Revitalizes dull and faded tires.
Poorboy's World Bold N Bright is a water-based tire dressing that nourishes the rubber while providing a deep black finish. The liquid absorbs quickly and leaves absolutely no greasy or sticky residue behind. This prevents new road grime from quickly adhering to the surface again. Furthermore, the formula is equipped with UV blockers to prevent further drying and brown discoloration caused by sunlight.
The dressing is versatile and can create both a subtle satin finish and a deep high gloss. A major advantage is that the product is dry to the touch, effectively preventing black splatters from slinging onto the car paint while driving. Because it is a water-based formula, the longevity will decrease slightly faster after heavy rain or intensive washes compared to a silicone-based dressing.
Product number: PB-BNB16
Consistency: Liquid
  1. Ensure a dry and thoroughly cleaned tire surface for the best results.
  2. Apply the liquid to an applicator pad or spray directly onto the rubber.
  3. Spread the dressing in a thin, even layer across the sidewall of the tire.
  4. Wipe off any excess product with a clean cloth.
Tips
  • Wipe the treated surface immediately with a microfiber towel for a subtle, matte factory look.
  • Allow the product to air dry completely without wiping to achieve a maximum, striking high gloss.
A very effective, easy-to-use tyre dressing that gives tyres a deep, natural black satin finish without greasy shine. Economical in use, pleasant smelling and versatile (works on dashboards and trim). Simple application with a cloth or applicator — great value.
11 - 3 of 31 reviews
Topkeuze
Lage waardering vanwege het feit dat het aanbrengen onhandig is. Afgezet tegen de Hot Wheel van Megulars die je gemakkelijk kan opsuiten moet je dit eerst op een doek doen en daarna op je banden. Hiermee verlies je veel product en ook is spuiten gemakkelijk op de banden dan aanbrengen met een doek. Er wordt overigens wel een losse spray bijgeleverd maar deze nevelt niet maar spuit een dikke straal op 1 plek, ook dit is niet erg handig. Of je moet zelf een goede spray hebben, dan kan het goed spul zijn gaat ongeveer evenlang mee (een week) als Megulars en is wel goedkoper. Dus vanwege bediening 2 sterren. Product zelf 4 sterren...
Jeff - 22/07/2008
Q²M Tire Express - 500ml
  • Zeer snelle bandendressing op waterbasis
  • Zowel nat als droog te verwerken
  • Geleverd met doseerpompje
  • Geeft een matte afwerking
€ 22.99
Poorboys World
Bold N Bright Gel - 473ml
  • Protective tire dressing gel
  • Very precise to apply
  • Dries without sticky residue
  • Provides strong UV protection
€ 21.99
Dodo Juice
Dark Matter Trim and Tyre Dressing
  • Kunststof- en bandendressing
  • Geeft een satijnen finish
  • Geen uitlopers in de regen
  • Gemakkelijk in gebruik
€ 18.99
Stjärnagloss
  • Satijnen afwerking
  • Geen uitlopers of vlekken
  • Prettige geur
€ 19,-
Temporarily unavailable
Get stock notification
