Bold N Bright Tire Dressing - 473ml
- Water-based car tire dressing
- Non-greasy and non-sticky
- Protects against UV radiation
- Zero paintwork sling effect
Poorboy's World Bold N Bright - Revitalizes dull and faded tires.
Poorboy's World Bold N Bright is a water-based tire dressing that nourishes the rubber while providing a deep black finish. The liquid absorbs quickly and leaves absolutely no greasy or sticky residue behind. This prevents new road grime from quickly adhering to the surface again. Furthermore, the formula is equipped with UV blockers to prevent further drying and brown discoloration caused by sunlight.
The dressing is versatile and can create both a subtle satin finish and a deep high gloss. A major advantage is that the product is dry to the touch, effectively preventing black splatters from slinging onto the car paint while driving. Because it is a water-based formula, the longevity will decrease slightly faster after heavy rain or intensive washes compared to a silicone-based dressing.
| Product number: | PB-BNB16 |
| Consistency: | Liquid |
Ensure a dry and thoroughly cleaned tire surface for the best results.
Apply the liquid to an applicator pad or spray directly onto the rubber.
Spread the dressing in a thin, even layer across the sidewall of the tire.
Wipe off any excess product with a clean cloth.
Tips
Wipe the treated surface immediately with a microfiber towel for a subtle, matte factory look.
Allow the product to air dry completely without wiping to achieve a maximum, striking high gloss.
9 - 3 of 31 reviews
Standaard
heel makkelijk in gebruik, geeft mooi resultaat en ruikt ook nog eens lekker! banden drogen mooi zwart op en blinken niet zo vettig als met andere produkten.
Voldoende
Makkelijk en snel aan te brengen met een spons. Zeer duurzaam en zuinig. Geeft een mooie zwarte look, wil geen andere meer proberen.
Gewoon aanbrengen op een oud washandje dit absorbeerd goed en voldoende aanbrengen en zo kan je het product dan ook met stevige kracht rondom de band aanbrengen, resultaat geen vuile handen en een zeer banden, banden blijven zelf weken tot enkele maanden mooi. prima spul
