Earn Polishpoints with every order for extra discounts! Discover more!
EXP Pure Sealant - 473ml
Art. nr. PB-EXP16oz
Poorboy's World EX-P Sealant - Long-lasting protection with an unmatched gloss
Poorboy's World EX-P Sealant is a pure synthetic protectant designed to shield automotive paintwork from environmental elements and dirt. This product creates a durable barrier that outlasts traditional carnauba waxes significantly. It delivers a glass-like shine and maximizes the clarity of light colors, metallics, and pearlescent finishes.
Since it is a pure sealant, the formula lacks cleaning or polishing particles. Therefore, application works best on a previously prepped and polished surface for optimal results. On the other hand, the application process is extremely simple. The product is effortless to apply and buff off. An ideal choice for long-lasting results and a mirror-smooth finish.
Product number: PB-EXP16oz
Consistency: Liquid
H315: Causes skin irritation.
  1. Wash and dry the vehicle thoroughly before use.
  2. Apply a small amount of product to a soft applicator pad.
  3. Spread the sealant in a thin, even layer across the paintwork.
  4. Allow the product to dry for 30 to 60 minutes until a haze forms.
  5. Buff off the residue gently using a clean microfiber towel.
Tips
  • For extra depth and shine, apply a layer of carnauba wax over the fully cured sealant.
  • Adding multiple thin layers provides maximum protection and an enhanced reflection.
A highly praised Poorboy's sealant: easy and economical to apply, gives deep, long‑lasting gloss and excellent water beading, cures and buffs out smoothly, smells of coconut; best applied thinly and topped with wax, but avoid unpainted plastics.
3 - 3 of 52 reviews
Prima
Het betreft een rode auto van 10 jaar oud. Twee jaar geleden is deze in de Waxoyl gezet, kort geleden was er wat schade en is de achterdeur en het scherm overgespoten. Het contrast in de glans was erg groot. Het gedeelte waar geen Waxoyl meer opzat heb ik 2x gedaan met EXP Pure Sealant. Dik tevreden over het eind resultaat een diepe glans heeft het weer en sluit prima aan op de rest van de auto.
Simons - 22/03/2023
Prachtige glans
Gebruikt op de motor. Eerst PB blackhole en daarna PB Sealant. Mooie glans, goede flake pop en ontzettend glad. De motor is daarna niet meer gebruikt en staat nog in de garage. Elke keer genieten als ik dan kijk, met name vanwege de glans en de flake pop. Ik heb moeite om de motor niet even aan te raken, om te voelen hoe glad deze is.
Frank - 23/09/2022
Goede sealant en makkelijk te verwerken. Opbrengen even laten drogen en uitwrijven. De sealant houdt lang zijn werking dat is te zien aan de de lak.
EX-P - 21/10/2021
Menzerna
Power Lock Ultimate Protection - 250ml
  • Hoogwaardige polymeren sealant
  • Duurzame bescherming tegen de elementen
  • Gemakkelijk in gebruik
  • Zowel handmatig als machinaal te verwerken
€ 17.99
Poorboys World
EX Sealant with Carnauba - 473ml
  • Sealant met carnaubawax
  • Geeft het oppervlak een diepe glans
  • Eenvoudig aan te brengen, ook in de zon!
  • Beschermt tot 6 maanden lang
€ 26.99
Offer
Turtle Wax
Seal N Shine Hybrid Sealant Wax - 500ml
  • Synthetische spray sealant
  • Extreme waterafstotendheid
  • Maandenlange bescherming
  • Eenvoudig en snel aanbrengen
Retail price: € 19.99 € 14.99
Last chance
Stjärnagloss
Pärla Spray Sealant-500ml
  • Spraysealant op waterbasis
  • Op een nat en droog paneel te gebruiken
  • Verdunbaar
€ 19,-
Has been discontinued
