EXP Pure Sealant - 473ml
- Synthetic paint protection sealant
- Very long-lasting durability
- Effortless to wipe off
Poorboy's World EX-P Sealant - Long-lasting protection with an unmatched gloss
Poorboy's World EX-P Sealant is a pure synthetic protectant designed to shield automotive paintwork from environmental elements and dirt. This product creates a durable barrier that outlasts traditional carnauba waxes significantly. It delivers a glass-like shine and maximizes the clarity of light colors, metallics, and pearlescent finishes.
Since it is a pure sealant, the formula lacks cleaning or polishing particles. Therefore, application works best on a previously prepped and polished surface for optimal results. On the other hand, the application process is extremely simple. The product is effortless to apply and buff off. An ideal choice for long-lasting results and a mirror-smooth finish.
| Product number: | PB-EXP16oz |
| Consistency: | Liquid |
Wash and dry the vehicle thoroughly before use.
Apply a small amount of product to a soft applicator pad.
Spread the sealant in a thin, even layer across the paintwork.
Allow the product to dry for 30 to 60 minutes until a haze forms.
Buff off the residue gently using a clean microfiber towel.
Tips
For extra depth and shine, apply a layer of carnauba wax over the fully cured sealant.
Adding multiple thin layers provides maximum protection and an enhanced reflection.
4 - 3 of 52 reviews
Goede glans en gemakkelijk aan te brengen
Auto vooraf met Black hole behandeld en daarna deze eroverheen. Verwerking is eenvoudig en de glans is fenomenaal (veel beter dan alleen maar black hole). Standtijd kan ik nog weinig over zeggen.
Super Sealant
Wat mij betreft mag het ook Super Sealant heten. Geweldig product, ik heb al het zoveelste flesje besteld. Tot nu toe gebruik ik alleen 473ml flesjes en daar gaan (kleine auto) echt veel autopoetsbeurten uit.
Poorboys EXP Pure Sealant
Zeer goed product dat een heel mooie glans geeft en ook nog eens lang blijft zitten. Heel eenvoudig aan te brengen onder diverse omstandigheden en evenzeer makkelijk uit te poetsen. Laat moeilijk verwijderbare witte zweem na op plastic of rubber delen. Los dit zelf heel eenvoudig op door eerst de kunststof delen met black to black te behandelen die er dan ook weer prachtig gevoed uitzien en vervolgens met EXP aan de slag te gaan.
