Earn Polishpoints with every order for extra discounts! Discover more!
EXP Pure Sealant - 473ml
Art. nr. PB-EXP16oz
Poorboy's World EX-P Sealant - Long-lasting protection with an unmatched gloss
Poorboy's World EX-P Sealant is a pure synthetic protectant designed to shield automotive paintwork from environmental elements and dirt. This product creates a durable barrier that outlasts traditional carnauba waxes significantly. It delivers a glass-like shine and maximizes the clarity of light colors, metallics, and pearlescent finishes.
Since it is a pure sealant, the formula lacks cleaning or polishing particles. Therefore, application works best on a previously prepped and polished surface for optimal results. On the other hand, the application process is extremely simple. The product is effortless to apply and buff off. An ideal choice for long-lasting results and a mirror-smooth finish.
Product number: PB-EXP16oz
Consistency: Liquid
H315: Causes skin irritation.
  1. Wash and dry the vehicle thoroughly before use.
  2. Apply a small amount of product to a soft applicator pad.
  3. Spread the sealant in a thin, even layer across the paintwork.
  4. Allow the product to dry for 30 to 60 minutes until a haze forms.
  5. Buff off the residue gently using a clean microfiber towel.
Tips
  • For extra depth and shine, apply a layer of carnauba wax over the fully cured sealant.
  • Adding multiple thin layers provides maximum protection and an enhanced reflection.
A highly praised Poorboy's sealant: easy and economical to apply, gives deep, long‑lasting gloss and excellent water beading, cures and buffs out smoothly, smells of coconut; best applied thinly and topped with wax, but avoid unpainted plastics.
5 - 3 of 52 reviews
Werkt goed, lange standtijd
Ongeveer een half jaar geleden heb ik EX-P gebruikt op mijn toen nieuwe auto om de lak goed te beschermen. Daar overheen heb ik Bathe+ gebruikt als extra hydrofobe afwerking. Ik ben niet zo'n actieve poetser, dus heb de materialen zorgvuldig uitgekozen. Nu, dus ruim een half jaar later, kan ik zeggen dat ik zeer tevreden ben over de EX-P. Ik was de auto ca. eens per kwartaal (sorry...) en moet constateren dat het vuil zich niet hecht aan de lak. Het is eenvoudig om de auto te foamen, licht te wassen en weer in de Bathe+ te foamen. De basislaag EX-P doet dus zijn werk goed. Wel is een waarschuwing op zijn plaats: zorg dat het niet op ongelakte kunststof delen komt. Daar trekt het gemakkelijk in en de witterige vlekken die je dan krijgt zijn slechts zéér lastig te verwijderen. Vooral bij matte kunststof zie je dat.
Philippe - 08/12/2019
Erg goed spul
Vandaag voor het eerst gebruikt, na het kleien van de auto, de witte Corsa voorzien van deze sealant, ik moet zeggen dat het me opviel dat de krasjes goed werden opgevuld en schoon werden gepoetst. Ook erg makkelijk aan te brengen maar dat is met Poorboys altijd wel. Moet hem alleen nog aftoppen met Poorboys Natty’s blue paste. Ben benieuwd naar de standtijd met deze twee gecombineerd. Ik raad deze zeker aan, niet alleen voor het gebruiksgemak maar ook voor de kostprijs en de geur van kokosnoten. Heel fijn spul.
Ron Meuleners - 02/03/2019
Kleur
Had een zwarte auto maar door dit spul is hij nu helemaal wit geworden. Moest het bij bij RDW opnieuw aanmelden vanwege de kleursverandering. Ben zeer content met deze kleur.
Lammert - 13/07/2018
Menzerna
Power Lock Ultimate Protection - 250ml
  • Hoogwaardige polymeren sealant
  • Duurzame bescherming tegen de elementen
  • Gemakkelijk in gebruik
  • Zowel handmatig als machinaal te verwerken
€ 17.99
Poorboys World
EX Sealant with Carnauba - 473ml
  • Sealant met carnaubawax
  • Geeft het oppervlak een diepe glans
  • Eenvoudig aan te brengen, ook in de zon!
  • Beschermt tot 6 maanden lang
€ 26.99
Offer
Turtle Wax
Seal N Shine Hybrid Sealant Wax - 500ml
  • Synthetische spray sealant
  • Extreme waterafstotendheid
  • Maandenlange bescherming
  • Eenvoudig en snel aanbrengen
Retail price: € 19.99 € 14.99
Last chance
Stjärnagloss
Pärla Spray Sealant-500ml
  • Spraysealant op waterbasis
  • Op een nat en droog paneel te gebruiken
  • Verdunbaar
€ 19,-
Has been discontinued
