Först Citrus Pre-Cleaner-5000ml
- Cleaner with natural oils
- Perfect for tough cleaning jobs
- Pleasant fragrance
- Economical to use
The first choice for tough cleaning jobs
When your car is really dirty, or it's time for spring cleaning, Först, a citrus Traffic Film Remover (TFR), makes the task easy.
Formulated with natural orange oil, it not only boosts cleaning power but also smells amazing!
Apply undiluted to areas that need extra attention, let the product sit for a moment to work its magic, and then rinse thoroughly with water.
Först Citrus Pre-Cleaner has more cleaning power than Snö Snow Foam because it doesn't have added air, has a higher pH, and works at full strength. The downside is that your wax and sealant may not tolerate it as well.
It's often unnecessary and wasteful to spray the entire car with Först Citrus Pre-Cleaner. Use it only on the areas that really need it, usually the lower parts of the car, like bumpers and sills. Först Citrus Pre-Cleaner is also perfect for cleaning door jambs or under the hood.
| Product number: | C08STF050C |
- Spray Först Citrus Pre-Cleaner evenly on the areas you want to treat.
- Allow the product to work for 2-5 minutes, then rinse it off with water, preferably using a pressure washer.
- Do not let it dry.
2 - 3 of 18 reviews
Top product
Heel goed om grotere vervuiling weg te krijgen. Een hele goede pre-wash
Zeer goed product
Aangenaam verrast van dit product. Doet zijn werk heel erg goed. Opspuiten , even wachten en daar de met de HD afspuiten. 1 van de betere pre-cleaners die ik gebruikt heb.
Topspul
Ideaal wanneer je (vooral in de donkere vieze natte maanden) de auto snel 'toonbaar' wilt hebben: Inspuiten, ff laten inwerken, met hoge druk afspuiten en zeker 80% van het vuil is eraf
