Premium Tire Brush
- Premium bandenborstel
- Perfect om bandenreinigers in te werken
- Voorzien van rubberen randen
- Gemaakt in de Verenigde Staten
The Premium Tire Brush is the ideal brush for thoroughly cleaning your tires, ensuring that tire dressing adheres optimally and provides long-lasting protection. Thanks to its convenient size, you can easily reach all areas, including hard-to-access seams and edges of your tires.
The brush is made from durable plastic and features a rubber bumper, keeping your wheels and wheel arches safe even if you accidentally push the brush against the edges. The handle is rubber for a firm, comfortable grip, even when your hands are wet or the brush is used under high pressure.
The 1.9 cm long nylon bristles are stiff enough to effectively loosen dirt and brake dust, yet flexible enough to prevent damage. This ensures a thorough clean with minimal effort. Additionally, the brush has a hole in the handle, allowing you to hang it after use for proper drying.
Users especially appreciate the compatibility with tire cleaners like Tire Cleaner or Gyeon, and praise the compact, sturdy design that feels comfortable in the hand while still providing powerful cleaning. Whether you’re a professional detailer or maintaining your own car, this brush delivers precision, durability, and ease of use in one.
| Product number: | CC-PTB |
- Combineer de Premium Tire Brush met een hoogwaardige bandenreiniger voor het beste resultaat.
- Bewaar de borstel apart van scherpe voorwerpen om de haren en rubberen stootrand te beschermen.
Pak de rubberen handgreep stevig vast en borstel met voldoende druk over de banden of kunststofdelen. Voor het beste resultaat combineer je de borstel met een hoogwaardige bandenreiniger.
Spoel de borstel na elk gebruik af met water om vuil en resten van reiniger te verwijderen. Laat hem vervolgens aan de ophangoog in de steel drogen op een koele en geventileerde plek.
De rubberen handgreep biedt in vrijwel alle omstandigheden een stevige grip. Bij extreem natte handen kan hij iets gladder aanvoelen, maar blijft goed hanteerbaar tijdens normaal gebruik.
Ja, de borstel heeft een rubberen stootrand die beschermt tegen krassen en stoten, waardoor je veilig kunt reinigen, zelfs bij krappe ruimtes rondom de velg en wielkast.
De borstel is ideaal voor het grondig reinigen van banden, rubbers en kunststof trimdelen. Door het vuil goed los te borstelen, wordt de hechting en duurzaamheid van een bandendressing optimaal.
Ja, de borstel is ook geschikt voor het voorzichtig reinigen van kunststof trimdelen, zolang je geen scherpe of delicate oppervlakken beschadigt.
Ja, de nylonharen van 1,9 cm zijn stug genoeg om vuil, remstof en zand effectief uit de banden te borstelen, maar flexibel genoeg om schade aan rubber of kunststof te voorkomen.
Log in
8 - 3 of 26 reviews
Perfecte banden borstel
Perfect in de hand liggende borstel. Ideaal van grootte om elke band te reinigen. Samen met de Gyeon Q²M TireCleaner ´magic combo´
Borstelen gaat hier heel goed mee
Komt precies overeen met de beschrijving. Goede kwaliteit! Precies wat ik zocht, de haren zijn niet hard maar ook niet zacht.
Lang naar gezocht en gevonden.
Reach every corner of your tires.
Compact size, maximum control
The Premium Tire Brush is small, handy, and fits perfectly in your hand. Thanks to its compact design, you can easily reach all hard-to-access areas of your tires, seams, and edges, ensuring dirt and brake dust are thoroughly removed. Ideal for those who value precision and efficiency when cleaning tires and trim.
Durable material and protective bumper.
Sturdy and safe to use
The brush is made from durable plastic and features a rubber bumper that protects your wheels and wheel arches during brushing. The nylon bristles are strong enough to remove stubborn dirt while remaining safe for rubber and plastic. This way, you get both power and safety in one brush.
Optimal grip and long-lasting durability.
Comfortable and easy to maintain
The ergonomic rubber handle provides a firm grip, even when the brush is wet or under pressure. After use, you can easily hang the brush by the hole in the handle to dry, keeping it tidy and extending its lifespan. This makes the Premium Tire Brush ideal for regular maintenance and professional use.
