Sidewall Bob Tyre Brush
- Brush for cleaning tires
- Ergonomically shaped
- 25mm stiff nylon bristles
Dirty, brown-stained tires take away from even the most perfectly detailed car. No matter how clean your wheels are, neglected tire sidewalls immediately draw attention away from all that hard work. That’s exactly where the Sidewall Bob Tyre Brush comes in.
Sidewall Bob is specifically designed for thoroughly cleaning tire sidewalls. The brush features 25 mm long, stiff nylon bristles that penetrate deep into the rubber, effectively loosening built-up grease, old tire dressings, and road grime. This removes the familiar brown haze and restores the tire’s original deep color. The bristles are firm enough to tackle stubborn dirt, yet safe for rubber when used correctly.
Thanks to its compact shape and comfortable grip, the brush sits nicely in the hand and offers good control while scrubbing, even when wet. This makes Sidewall Bob suitable for both quick washes and more intensive cleaning before applying a tire dressing. When combined with a tire clea
| Product number: | DJSB1PC |
- Rinse the tires with water first to remove loose dirt and sand. This prevents unnecessary wear and makes cleaning more effective.
- Apply a suitable tire cleaner to the tire sidewall or directly onto the brush. Make sure the surface is thoroughly wet.
- Scrub the tire sidewall with the Sidewall Bob using calm, even motions. Work your way around the tire and apply light to medium pressure to loosen grease, dirt, and old tire dressing.
- While cleaning, consciously keep the brush away from the wheels. The stiff nylon bristles are ideal for rubber but may damage wheels. Stay about one centimeter away from the wheel edge or treat those areas with extra care.
- Rinse the tire thoroughly with water until all cleaner and loosened contamination are removed.
- Rinse the brush thoroughly after each tire to remove built-up dirt and keep the bristles clean while working.
- Repeat the process if necessary on heavily contaminated tires. After cleaning, the tire is perfectly prepared for applying a tire dressing.
Maintenance tip: Rinse the brush thoroughly after use and allow it to air dry. This keeps the bristles in good condition and ensures the brush maintains its performance.
De borstel is speciaal ontworpen om bandenzijkanten grondig te reinigen en vieze, bruine aanslag te verwijderen, zodat de banden er weer verzorgd en diepzwart uitzien.
Spoel de borstel na elke band goed uit met water om opgehoopt vuil te verwijderen. Laat hem daarna aan de lucht drogen. Zo blijven de nylon haren in goede conditie en gaat de borstel langer mee.
Nee, de haren zijn stevig genoeg om banden schoon te maken, maar kunnen velgen beschadigen. Houd altijd ongeveer een centimeter afstand van de velgrand of werk deze randjes extra voorzichtig.
Sidewall Bob werkt goed met Pneu Look of een andere favoriete bandenreiniger. Breng de reiniger aan op de band of de borstel en schrob vervolgens de zijkant.
Log in
2 - 3 of 4 reviews
Matige borstel, wel een handig formaat
De haren van de borstel zijn heel erg stug, waardoor je moet oppassen voor je hoogglans velgen. Wel is het kleine formaat handig bij banden met een lage wang. Toch gebruik ik liever een stevige kwast. Door de witte haren zie je goed of de borstel vies is.
