- Glass polish for all automotive glass
- Perfect preparation for coatings
- Special formula for better bonding of the coating
- Manual and machine application
Effective Glass Polish and Pre-Coat Cleaner
Q²M GlassPolish efficiently removes stains and stubborn dirt from all types of automotive glass. It does not produce dust and can be applied by hand or with a polishing machine. Ideal as a preparation step before applying a rain-repellent product such as Q² QuickView (and Q² Repel, included in the Q² View EVO set).
Special Formula
The unique formula of Q²M GlassPolish makes it not only a highly effective pre-coating polish for glass coatings, but also an easy-to-use cleaner for any glass surface. It effectively removes stubborn mineral deposits and light hazes on glass.
Perfect Adhesion
Q²M GlassPolish contains active ingredients that aid in the adhesion of special glass coatings such as Q² QuickView or Q² View EVO.
| Product number: | GY-GLSPO12 |
Apply Q²M GlassPolish by hand or machine (rotary or dual-action). For instance, use with a Q²M Polish Pad (blue) at low speed and medium pressure. Never reuse the pad on paintwork, even after cleaning! Mark the pad to know it has been used with Q²M GlassPolish!
Work the product until a light haze forms. Then, wipe off using Q²M Prep.
2 - 3 of 4 reviews
Prima als voorbereiding op Gyeon View
Gebruik deze machinaal (met de blauwe Gyeon pad) als voorbereiding op de View coating. Zeer lichte krasjes (= krasjes die je ziet maar met je nagel niet kan voelen) en kalkvlekken zijn snel verdwenen.
