Bold N Bright Gel - 946ml
- Protective tire dressing gel
- Very precise to apply
- Dries without sticky residue
- Provides strong UV protection
Poorboy's World Bold N Bright Tyre Gel - Restore the deep black color of tires.
Poorboy's World Bold N Bright Tyre Gel is a gel-based tire dressing that nourishes the rubber and provides a dark, rich shine. This thick consistency allows for very precise application, effectively preventing overspray or splatters on the car paint. The water-based formula absorbs quickly and leaves absolutely no sticky or greasy layer behind. As a result, new road dirt does not get a chance to quickly adhere to the treated surface.
This gel is safe to use on all types of car tires and rubber trim. The product contains special UV blockers that prevent the rubber from further drying out or turning brown due to harmful sunlight. Because the gel penetrates deep into the rubber, the material remains soft and supple. The gel works excellently to create a subtle gloss without making the tires look unnatural.
| Product number: | PB-BNBG32 |
| Consistency: | Gel |
Ensure a dry and thoroughly cleaned tire surface.
Apply a small amount of gel onto a dedicated applicator pad.
Spread the product in an even layer across the sidewall of the tire.
Wipe off any excess residue with a clean microfiber towel.
Tips
Buff the rubber with a clean towel immediately after application for a subtle satin gloss.
Apply a second layer after an hour for an extra dark and striking finish.
Log in
5 - 3 of 15 reviews
Gemiddeld
Mooie halfglanzende look op de banden! Verwekt erg makkelijk op een foamapplicator of badstoffenapplicator. Eventueel met een kwast of borstel nabewerken voor de fijne/kleine stukjes in de banden. Een aanrader!
Geweldig
Heel goed spul dit. Ik had m'n whtie-line banden eerst goed schoon gemaakt met de All Purpose Cleaner van Poorboys World en daarna dit op de banden gedaan. Ze zien er echt als nieuw uit en het geeft een mooie glans, niet die hoogglans die je wel eens ziet, maar echt een diep zwarte zijde glans.
Acceptabel
Fijn spul. Ik ben mijn collectie aan het uitbreiden. Met alles van PB. Wat een top spul. BnB dus ook. De banden worden er mooi zwart van. En niet op een zo nep blinkend. Het is alleen wat lastig aanbrengen. Ik heb conti's met veel gaatjes en kieren. Daar gaat het spul dan ook tussen zitten. Even met een kwast nabewerken en weg is het.
